Reading outside normal range on SPS30
Hello, everyone.
I have a sps30 PM sensor hooked up to a wemos d1 mini (clone). Everything appears to be working perfectly, except for if I blow some smoke from a match or something at the senor. I expected to get a reading maxing out the senor at it’s rated 1000 uq/m3 for the PM2.5 sensor reading. but instead I can a reading 12k something. I’ve seen as high as 20k something. Way, way higher than it’s rated to report. Is there something amiss? This result is reflected in all readings, not just the 2.5 senor in case you were curious.
Anyone else notice this? When I’m not not messing with it I get a perfectly normal/expected reading.
