Hi, I’m trying to read one of the analog inputs from my PLC
Does anyone what to put into the config-file to be able to read the “AI” inputs?
anything that will help me will be much appreciated.
Hello @fesklord,
I have a LOGO where input registers are temperatures, they are short integer so if I read 321 it means 32.1°C.
I divide my configuration.yaml so I have to edit 3 files:
configuration.yaml:
modbus: !include modbus.yaml
template: !include templates.yaml
modbus.yaml (please note the host is your LOGO IP address, I store mine in the secrets.yaml file):
- name: "Siemens LOGO"
type: tcp
host: !sercret siemens_logo_ip
port: 502
sensors:
- name: "MyLOGO1"
unique_id: mylogo1
input_type: input
slave: 1
address: 0
count: 8
data_type: custom
structure: ">8h"
Note: structure:">8h" means I have reading 8 short number of 2 bytes each with big endian ending. You can read about Python structure here.
As I read all 8 input registers at once and then use a template to separate the values, then I have less modbus requests made to the LOGO. So I divide the values in templates.yaml:
- name: Heater temperature
state: "{{ states('sensor.mylogo1').split(',')[0] | multiply(0.1) }}"
state_class: measurement
unit_of_measurement: °C
- name: External temperature
state: "{{ states('sensor.mylogo1').split(',')[1] | multiply(0.1) }}"
# and so on until states('sensor.mylogo1').split(',')[7]
I hope that helps and do not hesitate to reach out if you have any question.
@cloom, thank you!
