Hi again
So I think i might have nailed the entire thing.
Wanting to have light color change during day, and if I change it from the HUE app, activate a switch to indicate that manual control is active.
If manual control is turned off, reset color to auto.
What is not considered yet, is what happens if the manual override switch is turned off after the lights are turned off.
I did do it different before, but I think this is more streamlined way to do it.
The code can show signs of some of the old code.
configuration.yaml
input_boolean:
manualstuen2:
name: "Stue2 lys manuelt tændt"
icon: mdi:lightbulb-on
initial: off
Node -red
[{"id":"8a031fad.97f44","type":"subflow","name":"Save Light settings","info":"","category":"","in":[{"x":20,"y":80,"wires":[{"id":"9ae81bf4.ab8d98"}]}],"out":[{"x":360,"y":80,"wires":[{"id":"9ae81bf4.ab8d98","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"9ae81bf4.ab8d98","type":"function","z":"8a031fad.97f44","name":"Save Light settings","func":"\n// Array in global https://stackoverflow.com/questions/49481558/node-red-global-array-variable-get-set-not-seeming-to-work\n// global.set(\"arrOldSettings[\"+i+\"], i);\n\n// A mired is a microreciprocal degree. It’s derived by dividing 1,000,000 by the Kelvin temperature. So 5600K has a mired of 180 (1,000,000/5600 = 179.57).\n// https://www.tvtechnology.com/opinions/the-art-of-the-mired-measurement\n\nvar MyLight = msg.payload;\nvar OldSettings = global.get(\"OldSettings\");\nvar new_msg = \"\";\n\nif ( typeof msg !== \"undefined\" ) {\n if ( typeof msg.data !== \"undefined\" ) {\n if ( typeof msg.data.attributes !== \"undefined\" ) {\n\n if ( typeof msg.data.attributes.rgb_color !== \"undefined\" ) {\n OldSettings[ MyLight + 'lightcolorr' ] = msg.data.attributes.rgb_color[0];\n OldSettings[ MyLight + 'lightcolorg' ] = msg.data.attributes.rgb_color[1];\n OldSettings[ MyLight + 'lightcolorb' ] = msg.data.attributes.rgb_color[2];\n new_msg.payload = \"Saved following as default rgb_color for \" + MyLight + \": \" + msg.data.attributes.rgb_color;\n } else if ( typeof msg.data.attributes.color_temp !== \"undefined\" ){ \n //get the mired value\n // The Mired to Kelvin value is devided by 100 to round it and then multiplyed by 100, to achive a round kelvin number of eg 2600 (Instead of 2577 at 388 Mired)\n var MiredToKelvin = ( (Math.round( (1000000 / msg.data.attributes.color_temp) / 100 ) ) * 100 );\n\n OldSettings[ MyLight + 'lightcolorr' ] = OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['R'];\n OldSettings[ MyLight + 'lightcolorg' ] = OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['G'];\n OldSettings[ MyLight + 'lightcolorb' ] = OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['B'];\n \n new_msg.payload = new_msg.payload + \"Saved following as default color_temp (\" + msg.data.attributes.color_temp + \") convert to kelvin (\" + MiredToKelvin + \") convert to RGB (\" + OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['R'] + \", \" + OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['G'] + \", \" + OldSettings[\"ArrKelvinConvert\"][MiredToKelvin]['B'] + \") for \" + MyLight;\n } else { new_msg.error = \"fail4\"; }\n\n if ( \"brightness\" in msg.data.attributes ) {\n OldSettings[ MyLight + 'brightness'] = msg.data.attributes.brightness;\n new_msg.payload = new_msg.payload + \" ::: Set \" + MyLight + \"Brightness = \" + OldSettings[ MyLight + 'brightness' ];\n } else { new_msg.error = \"fail5\"; }\n\n } else { new_msg.error = \"fail3\" }\n } else { new_msg.error = \"fail2\" }\n} else { new_msg.error = \"fail1\" }\n\nglobal.set(\"OldSettings\", OldSettings);\n\nreturn new_msg;","outputs":1,"noerr":0,"x":190,"y":80,"wires":[[]]},{"id":"96e64d5a.9d8c1","type":"subflow","name":"Stuen2 On","info":"","category":"","in":[{"x":40,"y":40,"wires":[{"id":"9335e183.91a65"},{"id":"71b91873.6ae738"}]}],"out":[],"env":[]},{"id":"9335e183.91a65","type":"api-call-service","z":"96e64d5a.9d8c1","name":"Stuen2 On","server":"468387c0.b24028","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.hue_color_lamp_1_3","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":670,"y":40,"wires":[[]]},{"id":"d1fcdc8a.8840f","type":"debug","z":"96e64d5a.9d8c1","name":"Stuen2 Subflow 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":80,"wires":[]},{"id":"992bb09e.cdb19","type":"api-current-state","z":"96e64d5a.9d8c1","name":"Stuen2 Light Already On?","server":"468387c0.b24028","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"light.hue_color_lamp_1_3","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":410,"y":200,"wires":[["d99838f4.3d3d68"],["71b91873.6ae738"]]},{"id":"71b91873.6ae738","type":"delay","z":"96e64d5a.9d8c1","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":460,"y":140,"wires":[["992bb09e.cdb19"]]},{"id":"40272f52.2bc0a","type":"debug","z":"96e64d5a.9d8c1","name":"Stuen2 Subflow 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":120,"wires":[]},{"id":"4e1dd6ff.b9d428","type":"debug","z":"96e64d5a.9d8c1","name":"Stuen2 Subflow 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":160,"wires":[]},{"id":"437be4de.f1c26c","type":"change","z":"96e64d5a.9d8c1","name":"Stuen2","rules":[{"t":"set","p":"payload.name","pt":"msg","to":"stuen2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":200,"wires":[["73046ae2.c642d4"]]},{"id":"73046ae2.c642d4","type":"subflow:8a031fad.97f44","z":"96e64d5a.9d8c1","name":"","env":[],"x":890,"y":200,"wires":[[]]},{"id":"d99838f4.3d3d68","type":"change","z":"96e64d5a.9d8c1","name":"CleanBox","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.colorb","pt":"msg","to":"data.attributes.rgb_color[2]","tot":"msg"},{"t":"set","p":"payload.entity_id","pt":"msg","to":"data.entity_id","tot":"msg"},{"t":"set","p":"payload.state","pt":"msg","to":"data.state","tot":"msg"},{"t":"set","p":"payload.brightness","pt":"msg","to":"data.attributes.brightness","tot":"msg"},{"t":"set","p":"payload.color_temp","pt":"msg","to":"data.attributes.color_temp","tot":"msg"},{"t":"set","p":"payload.colorr","pt":"msg","to":"data.attributes.rgb_color[0]","tot":"msg"},{"t":"set","p":"payload.colorg","pt":"msg","to":"data.attributes.rgb_color[1]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":260,"wires":[["437be4de.f1c26c"]]},{"id":"7d074c78.101bd4","type":"function","z":"b7656499.b2541","name":"Light Box","func":"// Version 4 of 9/1-2020\n\n// Array in global https://stackoverflow.com/questions/49481558/node-red-global-array-variable-get-set-not-seeming-to-work\n// global.set(\"arrOldSettings[\"+i+\"], i);\n\n\n//if ( typeof global.get(\"OldSettings\") == 'object' ){\n var OldSettings = global.get(\"OldSettings\");\n//}\n\nvar Payload_Name = \"default\";\nvar Payload_Entity_ID = \"default\";\nvar Payload_Manual_Switch = \"\";\nvar Payload_State = \"on\";\nvar Payload_Brightness = 0;\nvar Payload_Transition = 1;\nvar Payload_Color_Temp = 0;\n//var Payload_Color_RGB = { \"R\": 0, \"G\": 0, \"B\": 0 };\nvar Payload_Desired_Brightness = 128;\nvar Payload_Desired_Color_Temp = 250;\nvar RGB_Tolerance = OldSettings[ 'RGB_Tolerance' ];\nvar strLightMsg = msg; // The msg for setting light options\nvar intSetManualOverride = 0; // 0 = auto, 1 = manual override\nvar strSetManualOverrideMsg = msg; // The msg for setting manual override state\nstrLightMsg.payload.debug = { \"debug_start\": \"Start debugging\" };\nvar Payload_Force_To_Auto = 0;\n\nif ( typeof msg !== \"undefined\" ) {\n if ( typeof msg.payload !== \"undefined\" ) {\n if ( typeof msg.payload.name !== \"undefined\" ) {\n Payload_Name = msg.payload.name;\n }\n if ( typeof msg.payload.light !== \"undefined\" ) {\n Payload_Entity_ID = msg.payload.light;\n }\n if ( typeof msg.payload.manual_switch !== \"undefined\" ) {\n Payload_Manual_Switch = msg.payload.manual_switch;\n }\n if ( typeof msg.payload.state !== \"undefined\" ) {\n Payload_State = msg.payload.state;\n }\n if ( typeof msg.payload.brightness !== \"undefined\" ) {\n Payload_Brightness = msg.payload.brightness;\n }\n if ( typeof msg.payload.color_temp !== \"undefined\" ) {\n Payload_Color_Temp = msg.payload.color_temp;\n }\n// if ( typeof msg.payload.color_rgb !== \"undefined\" ) {\n// Payload_Color_RGB = msg.payload.color_rgb;\n// }\n if ( typeof msg.payload.transition !== \"undefined\" ) {\n if ( msg.payload.transition === 0 ) {\n Payload_Transition = OldSettings[Payload_Name][\"default\"][\"transition\"];\n } else {\n Payload_Transition = msg.payload.transition;\n }\n }\n if ( typeof msg.payload.desired_brightness !== \"undefined\" ) {\n if ( msg.payload.desired_brightness === 0 ) {\n Payload_Desired_Brightness = OldSettings[Payload_Name][\"default\"][\"brightness\"];\n } else {\n Payload_Desired_Brightness = msg.payload.desired_brightness;\n }\n }\n if ( typeof msg.payload.desired_color_temp !== \"undefined\" ) {\n if ( msg.payload.desired_color_temp === 0 ) {\n Payload_Desired_Color_Temp = OldSettings[Payload_Name][\"default\"][\"color_temp\"];\n } else {\n Payload_Desired_Color_Temp = msg.payload.desired_color_temp;\n }\n }\n if ( typeof msg.payload.desired_rgb !== \"undefined\" ) {\n if ( msg.payload.desired_rgb === 0 ) {\n Payload_Desired_RGB = OldSettings[Payload_Name][\"default\"][\"color_rgb\"];\n } else {\n Payload_Desired_RGB = msg.payload.desired_rgb;\n }\n // missing saving of RGB because of troubles with the arrays\n }\n if ( typeof msg.payload.forced_to_auto !== \"undefined\" ) {\n Payload_Force_To_Auto = msg.payload.forced_to_auto;\n }\n }\n\n var OldSettings_Current_Color_Temp = OldSettings[Payload_Name][\"current\"][\"color_temp\"];\n var OldSettings_Current_Brightness = OldSettings[Payload_Name][\"current\"][\"brightness\"];\n\n if ( Payload_State == \"on\" ) {\n strLightMsg.payload.debug.debug1 = \"Payload_State == 'on'\";\n if ( Payload_Force_To_Auto === 0) {\n strLightMsg.payload.debug.debug2 = \"Payload_Force_To_Auto === 0\";\n if ( Payload_Color_Temp > 0) {\n if ( ( Payload_Color_Temp > ( OldSettings_Current_Color_Temp + RGB_Tolerance ) ) || ( Payload_Color_Temp < ( OldSettings_Current_Color_Temp - RGB_Tolerance ) ) ) {\n intSetManualOverride = 1;\n strLightMsg.payload.debug.debug3 = \"SetManualOverride = 1 because of Payload_Color_Temp \" + Payload_Color_Temp + \" <> \" + OldSettings_Current_Color_Temp + \" +- \" + RGB_Tolerance;\n } else {\n strLightMsg.payload.debug.debug3 = \"Not setting SetManualOverride because of Payload_Color_Temp \" + Payload_Color_Temp + \" = \" + OldSettings_Current_Color_Temp + \" +- \" + RGB_Tolerance;\n }\n } else {\n strLightMsg.payload.debug.debug3 = \"Color_temp not supplied or < 0\";\n }\n if ( ( Payload_Brightness > ( OldSettings_Current_Brightness + RGB_Tolerance ) ) || ( Payload_Brightness < ( OldSettings_Current_Brightness - RGB_Tolerance ) ) ) {\n intSetManualOverride = 1;\n strLightMsg.payload.debug.debug4 = \"SetManualOverride = 1 because of Payload_Brightness \" + Payload_Brightness + \" <> \" + OldSettings_Current_Brightness + \" +- \" + RGB_Tolerance;\n } else {\n strLightMsg.payload.debug.debug4 = \"Not setting SetManualOverride because of Payload_Brightness\" + Payload_Brightness + \" = \" + OldSettings_Current_Brightness + \" +- \" + RGB_Tolerance;\n }\n } else {\n strLightMsg.payload.debug.debug2 = \"Payload_Force_To_Auto === 1\";\n }\n } else {\n strLightMsg.payload.debug.debug1 = \"Payload_State == 'off'\";\n }\n\n\n if ( (intSetManualOverride === 0) ){\n if ( Payload_Desired_Color_Temp > 0 ){ // If kelvin is set in function call\n \n Payload_Desired_Color_Temp = ( Payload_Desired_Color_Temp > 500 ) ? 500 : Payload_Desired_Color_Temp;\n Payload_Desired_Color_Temp = ( Payload_Desired_Color_Temp < 153 ) ? 153 : Payload_Desired_Color_Temp;\n // If color temp is above or below hue limitations\n strLightMsg.payload.data = {\n 'brightness': Payload_Desired_Brightness, // Brightness 1-255 from function call\n 'color_temp': Payload_Desired_Color_Temp, // Color temp 153-500 from function call\n 'transition': Payload_Transition // Transition time from function call\n };\n strLightMsg.payload.debug.debug5 = \"Setting light options with color_temp: \" + Payload_Desired_Color_Temp + \" and brightness: \" + Payload_Desired_Brightness + \" and transition: \" + Payload_Transition;\n } else if ( (Payload_Desired_RGB[\"R\"] > 0) || (Payload_Desired_RGB[\"B\"] > 0) || (Payload_Desired_RGB[\"G\"] > 0) ){\n // Else if RGB color is set in funciton call\n strLightMsg.payload.data = {\n 'brightness': Payload_Desired_Brightness, // Brightness 1-255 from function call\n 'rgb_color': Payload_Desired_RGB, // RGB Color from function call\n 'transition': Payload_Transition // Transition time from function call\n };\n strLightMsg.payload.debug.debug5 = \"Setting light options with RGB: \" + Payload_Desired_RGB + \" and brightness: \" + Payload_Desired_Brightness + \" and transition: \" + Payload_Transition;\n } else { // If no RGB or Kelvin color was set in function call\n strLightMsg.payload.data = {\n 'brightness': 200, // Brightness 1-255\n 'color_temp': 350, // Color temp\n 'transition': 1 // Transition time\n };\n strLightMsg.payload.debug.debug6 = \"Setting light options to default - ERROR in supplied data\";\n }\n }\n}\n\nglobal.set(\"OldSettings\", OldSettings);\n\nif ( intSetManualOverride == 1 ){\n strSetManualOverrideMsg.payload.entity_id = Payload_Manual_Switch;\n strSetManualOverrideMsg.payload.debug = strLightMsg.payload.debug;\n strSetManualOverrideMsg.payload.debug.debug7 = \"strLightMsg = null\";\n strLightMsg = null;\n} else {\n strSetManualOverrideMsg = null;\n strLightMsg.payload.debug.debug8 = \"strSetManualMsg = null\";\n OldSettings[Payload_Name][\"current\"][\"brightness\"] = Payload_Desired_Brightness;\n OldSettings[Payload_Name][\"current\"][\"color_temp\"] = Payload_Desired_Color_Temp;\n}\n\nreturn [\n strLightMsg,\n strSetManualOverrideMsg,\n];\n\n\n\n","outputs":2,"noerr":0,"x":500,"y":4080,"wires":[["896af69c.f4a1e8","b4600bdb.8d10b8"],["89b17d9e.1d8eb","e7735460.a78368"]]},{"id":"f2dd1cb5.b2734","type":"inject","z":"b7656499.b2541","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":3980,"wires":[["d6e36bb5.c79488"]]},{"id":"945ee9b8.4b1858","type":"api-current-state","z":"b7656499.b2541","name":"Get Light States","server":"c07167d6.bc6238","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"str","state_location":"","override_payload":"none","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":520,"y":3980,"wires":[["9913f88c.cb58f8","4a24789c.238e08"],[]]},{"id":"c9ff405f.1320d","type":"debug","z":"b7656499.b2541","name":"Debug 1","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":880,"y":3940,"wires":[]},{"id":"9913f88c.cb58f8","type":"change","z":"b7656499.b2541","name":"CleanBox","rules":[{"t":"set","p":"payload.state","pt":"msg","to":"data.state","tot":"msg"},{"t":"set","p":"payload.colorb","pt":"msg","to":"data.attributes.rgb_color[2]","tot":"msg"},{"t":"set","p":"payload.brightness","pt":"msg","to":"data.attributes.brightness","tot":"msg"},{"t":"set","p":"payload.color_temp","pt":"msg","to":"data.attributes.color_temp","tot":"msg"},{"t":"set","p":"payload.colorr","pt":"msg","to":"data.attributes.rgb_color[0]","tot":"msg"},{"t":"set","p":"payload.colorg","pt":"msg","to":"data.attributes.rgb_color[1]","tot":"msg"},{"t":"set","p":"payload.light","pt":"msg","to":"payload.entity_id","tot":"msg"},{"t":"set","p":"payload.data.entity_id","pt":"msg","to":"payload.manual_switch","tot":"msg"},{"t":"set","p":"payload.entity_id","pt":"msg","to":"payload.manual_switch","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":3980,"wires":[["a5554af6.92add8","c9ff405f.1320d"]]},{"id":"a5554af6.92add8","type":"change","z":"b7656499.b2541","name":"Desired Brightness","rules":[{"t":"set","p":"payload.desired_brightness","pt":"msg","to":"0 = Default Brightness","tot":"str"},{"t":"set","p":"payload.desired_brightness","pt":"msg","to":"0","tot":"num"},{"t":"set","p":"payload.desired_transition","pt":"msg","to":"0 = Default Transition","tot":"str"},{"t":"set","p":"payload.desired_transition","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":910,"y":3980,"wires":[["4be98c7e.b36814","7f45aa4f.04b434"]]},{"id":"4be98c7e.b36814","type":"change","z":"b7656499.b2541","name":"Desired Color","rules":[{"t":"set","p":"payload.desired_color_temp","pt":"msg","to":"0 = Default [ 153-500 ]","tot":"str"},{"t":"set","p":"payload.desired_color_temp","pt":"msg","to":"350","tot":"num"},{"t":"set","p":"payload.desired_rgb","pt":"msg","to":"0 = disabled","tot":"str"},{"t":"set","p":"payload.desired_rgb","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1120,"y":3980,"wires":[["72630aa0.a6cfb4","c8e8d9dd.cdb838"]]},{"id":"7f45aa4f.04b434","type":"debug","z":"b7656499.b2541","name":"Debug 2","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1100,"y":3940,"wires":[]},{"id":"72630aa0.a6cfb4","type":"debug","z":"b7656499.b2541","name":"Debug 3","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1300,"y":3940,"wires":[]},{"id":"c8e8d9dd.cdb838","type":"api-current-state","z":"b7656499.b2541","name":"If Manual Override is Off","server":"468387c0.b24028","version":1,"outputs":2,"halt_if":"false","halt_if_type":"bool","halt_if_compare":"is","override_topic":false,"entity_id":"","state_type":"habool","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":250,"y":4040,"wires":[["c63a0f0d.ea5cf","7d074c78.101bd4"],["a736e0f.077512"]]},{"id":"c63a0f0d.ea5cf","type":"debug","z":"b7656499.b2541","name":"Debug 4","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":500,"y":4040,"wires":[]},{"id":"b4600bdb.8d10b8","type":"subflow:96e64d5a.9d8c1","z":"b7656499.b2541","name":"","env":[],"x":710,"y":4080,"wires":[]},{"id":"896af69c.f4a1e8","type":"debug","z":"b7656499.b2541","name":"Debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":700,"y":4040,"wires":[]},{"id":"89b17d9e.1d8eb","type":"debug","z":"b7656499.b2541","name":"Debug 6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":700,"y":4180,"wires":[]},{"id":"a736e0f.077512","type":"debug","z":"b7656499.b2541","name":"Debug 7","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":500,"y":4120,"wires":[]},{"id":"e7735460.a78368","type":"api-call-service","z":"b7656499.b2541","name":"Set Manual Override On","server":"c07167d6.bc6238","version":1,"debugenabled":false,"service_domain":"input_boolean","service":"turn_on","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":750,"y":4120,"wires":[["2687c5ef.51b00a"]]},{"id":"c7b2d83b.1c4ac8","type":"server-state-changed","z":"b7656499.b2541","name":"Settings (Manual turns off)","server":"c07167d6.bc6238","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.manualstuen2","entityidfiltertype":"exact","outputinitially":false,"state_type":"habool","haltifstate":"false","halt_if_type":"bool","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":230,"y":3900,"wires":[["efa77c7b.5e0d6"],[]]},{"id":"efa77c7b.5e0d6","type":"change","z":"b7656499.b2541","name":"CleanBox","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"data","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"},{"t":"set","p":"data","pt":"msg","to":"{\"force_to_auto\":\"1\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":3900,"wires":[["d6e36bb5.c79488","b9590be5.0e1e38"]]},{"id":"d6e36bb5.c79488","type":"change","z":"b7656499.b2541","name":"Settings","rules":[{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"payload.forced_to_auto","pt":"msg","to":"data.force_to_auto","tot":"msg"},{"t":"delete","p":"data","pt":"msg"},{"t":"set","p":"payload.name","pt":"msg","to":"livingroom2","tot":"str"},{"t":"set","p":"payload.entity_id","pt":"msg","to":"light.hue_color_lamp_1_3","tot":"str"},{"t":"set","p":"payload.manual_switch","pt":"msg","to":"input_boolean.manualstuen2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":3980,"wires":[["945ee9b8.4b1858","779bb38c.bb787c"]]},{"id":"2687c5ef.51b00a","type":"debug","z":"b7656499.b2541","name":"Debug 8","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":960,"y":4120,"wires":[]},{"id":"b9590be5.0e1e38","type":"debug","z":"b7656499.b2541","name":"Debug 9","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":580,"y":3900,"wires":[]},{"id":"779bb38c.bb787c","type":"debug","z":"b7656499.b2541","name":"Debug 0","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":500,"y":3940,"wires":[]},{"id":"4a24789c.238e08","type":"debug","z":"b7656499.b2541","name":"Debug 0.1","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":3940,"wires":[]},{"id":"d57d8b78.1e1c38","type":"function","z":"b7656499.b2541","name":"Set Default Kelvin and Brightness","func":"\n// Automatically create the global array\nvar OldSettings;\n\nif ( typeof global.get(\"OldSettings\") !== 'object' ){\n OldSettings = { \n RGB_Tolerance: 4,\n intDefaultKelvin: 250,\n intDefaultBrightness: 128,\n intDefaultTransition: 1,\n ArrKelvinConvert: 0,\n \"default\": {\n \"brightness\": 128,\n \"transition\": 1,\n \"color_temp\": 250,\n \"color_rgb\": { \"R\": 0, \"G\": 0, \"B\": 0 }\n },\n\n \"livingroom2\": {\n \"default\": {\n \"brightness\": 128,\n \"transition\": 1,\n \"color_temp\": 250,\n \"color_rgb\": { \"R\": 0, \"G\": 0, \"B\": 0 }\n },\n \"current\": {\n \"brightness\": 0,\n \"color_temp\": 0,\n \"color_rgb\": { \"R\": 0, \"G\": 0, \"B\": 0 }\n },\n },\n\n }\n} else {\n OldSettings = global.get(\"OldSettings\");\n}\n\nvar intDate = new Date();\nvar intHours = intDate.getHours();\n\nswitch ( intHours ) {\n case 18:\n OldSettings[\"intDefaultKelvin\"] =\"3700\";\n OldSettings[\"intDefaultBrightness\"] =\"128\";\n OldSettings[\"intDefaultTransition\"] =\"5\";\n \n OldSettings[\"livingroom2\"][\"default\"][\"color_temp\"] = OldSettings[\"default\"][\"color_temp\"];\n OldSettings[\"livingroom2\"][\"default\"][\"brightness\"] = OldSettings[\"default\"][\"brightness\"];\n\n break;\n default:\n OldSettings[\"intDefaultKelvin\"] =\"3500\";\n OldSettings[\"intDefaultBrightness\"] =\"128\";\n OldSettings[\"intDefaultTransition\"] =\"1\";\n \n OldSettings[\"livingroom2\"][\"default\"][\"color_temp\"] = OldSettings[\"default\"][\"color_temp\"];\n OldSettings[\"livingroom2\"][\"default\"][\"brightness\"] = OldSettings[\"default\"][\"brightness\"];\n\n}\n\nglobal.set(\"OldSettings\", OldSettings);\nmsg.payload = { data: { OldSettings } };\n\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":3840,"wires":[["b0a18b3.4808c78"]]},{"id":"875e3387.7e898","type":"inject","z":"b7656499.b2541","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":3840,"wires":[["d57d8b78.1e1c38"]]},{"id":"b0a18b3.4808c78","type":"debug","z":"b7656499.b2541","name":"Test","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":3840,"wires":[]},{"id":"c07167d6.bc6238","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true},{"id":"468387c0.b24028","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false}]
