Reading switch values in function blocks
Hi guys.
I have a need to use the state of a dummy switch from home assistant in a node red function block. I normally use a poll state node and set a global variable then read that value in the function block. This works fine but is there a way that I can simply call something from the function block or is what I am doing right?
Look in the info panel of the server config node for an example.
edit:
here’s another example
Thank you heaps
