Ready made esphome devices
I recently bought two SLWF-01Pro by SMLIGHT Firmware: 2.1 (ESPHome 2024.4.2) dongles.
They were detected and working no problem, but should they come up in esphome builder too ?
Hi
If they have been programmed properly they should show up as devices ready for adoption (which allows to import the code flashed in it through github).
Vincèn
Hm ok. I can connect them by adding new device with the same name, and they appear online. But ofcourse with default config…
Here they have yaml online, but it is outdated a bit, validating it gives an error.
INFO ESPHome 2025.10.4
INFO Reading configuration /config/esphome/air-conditioner-866e3a.yaml...
Failed config
esphome: [source /config/esphome/air-conditioner-866e3a.yaml:16]
  friendly_name: Air Conditioner
  name_add_mac_suffix: True
  project:
    version: 2.1
  Please remove the `platform` key from the [esphome] block and use the correct platform component. This style of configuration has now been removed.
  platform: ESP8266
  board: esp12e
That code is outdated long time ago.
esp8266:
  board: esp12e
Yeah i just googled it, thnx.
