Imygaf
                    January 30, 2024,  5:27pm
                  41
              Ok so I added the Islamic month sensor. I wasn’t sure what to put for the value so I just added “none” and the automation saved successfully. Will see now if it plays at Isha time.
I tried to run actions and nothing played but I noticed that it changed volume of my echo to zero. Is that expected?
                raub21
                    February 24, 2024, 11:29pm
                  42
              @Aaliankhan . Could please explain what to put in the Islamic month sensor value like in the pictures:
                Aaliankhan
                    February 25, 2024, 12:28am
                  43
              You put the value the sensor will output when it’s Ramadan. For me that’s “Ramaḍān”
                raub21
                    February 25, 2024,  7:06am
                  44
              Jazaka Allah Khayran brother!
              I can’t play anything (even with a single action automation for test ) on any media player even the TVs…what am I missing
              how did you add the volume?
                Aaliankhan
                    March 14, 2024,  8:35pm
                  47
              There is a change volume in one of the options.
              I used to have the volume option since I imported the latest version, I don’t see it anymore
              me too also I can not play any media at all (not related to the blueprint )
                Aaliankhan
                    March 16, 2024, 10:16am
                  50
              Interesting, it seems like an issue with media playback itself. @thedamn316  @aelsharawi  Can you guys share some logs?
              s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service alsa: starting
s6-rc: info: service alsa successfully started
s6-rc: info: service alsa-init: starting
[01:12:14] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
s6-rc: info: service alsa-init successfully started
s6-rc: info: service pulseaudio: starting
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user 'root' is not '/var/run/pulse', ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that's impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card0: No such file or directory
s6-rc: info: service pulseaudio successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
              ogger: homeassistant.components.automation.adhan_announcement
Source: helpers/script.py:1805
integration: Automation (documentation, issues)
First occurred: 12:04:00 PM (3 occurrences)
Last logged: 12:04:00 PM
🔊 Adhan Announcement: Choose at step 1: choice 1: Choose at step 1: choice 3: Error executing script. Invalid data for call_service at pos 1: must contain at least one of entity_id, device_id, area_id.
🔊 Adhan Announcement: Choose at step 1: choice 1: Error executing script. Invalid data for choose at pos 1: must contain at least one of entity_id, device_id, area_id.
🔊 Adhan Announcement: Error executing script. Invalid data for choose at pos 1: must contain at least one of entity_id, device_id, area_id.
                Aaliankhan
                    March 16, 2024, 12:16pm
                  53
              It seems like the blueprint is missing the entity IDs to play. Or the entity IDs to pause.
Can you share the trace of the automation?
FYI, I am running same version with it working.
              choose:
  - conditions:
      - condition: state
        entity_id: sensor.islamic_month
        state: Ramaḍān
    sequence:
      - choose:
          - conditions:
              - condition: and
                conditions:
                  - condition: trigger
                  - condition: template
                    value_template: '{{ play_fajr == true }}'
            sequence:
              - service: media_player.media_pause
                target: {}
                data: {}
              - service: media_player.play_media
                  entity_id: media_player.clock_alexa
                  area_id: reception
                  device_id: removed here
                  media_content_id: >-
                    https://github.com/AalianKhan/adhans/blob/5787805ae3bc1c57ac88b37163ab673be429eb02/suhoor_dua.mp3?raw=true
                  media_content_type: mp3
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
              - wait_template: '{{ is_state(wait_media_player, ''idle'') }}'
                timeout: '00:05:00'
                  area_id: reception
                    https://github.com/AalianKhan/adhans/blob/5787805ae3bc1c57ac88b37163ab673be429eb02/adhan_fajr.mp3?raw=true
                value_template: '{{ media_resume }}'
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
              - service: media_player.media_play
                target: {}
                data: {}
          - conditions:
            sequence:
                target: {}
                data: {}
                  area_id: reception
                    https://github.com/AalianKhan/adhans/blob/5787805ae3bc1c57ac88b37163ab673be429eb02/iftar_dua.mp3?raw=true
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                    https://github.com/AalianKhan/adhans/blob/5787805ae3bc1c57ac88b37163ab673be429eb02/adhan.mp3?raw=true
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                target: {}
                data: {}
          - conditions:
              - condition: or
                conditions:
            sequence:
                target: {}
                data: {}
                  area_id: reception
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                target: {}
                data: {}
default:
  - choose:
      - conditions:
          - condition: and
            conditions:
        sequence:
            target: {}
            data: {}
              area_id: reception
          - delay:
              hours: 0
              minutes: 0
              seconds: 2
              milliseconds: 0
            timeout: '00:05:00'
            target: {}
            data: {}
      - conditions:
          - condition: or
            conditions:
        sequence:
            target: {}
            data: {}
              area_id: reception
          - delay:
              hours: 0
              minutes: 0
              seconds: 2
              milliseconds: 0
            timeout: '00:05:00'
            target: {}
            data: {}
                Aaliankhan
                    March 16, 2024, 12:53pm
                  55
Can you try to select one of your media players in the pause option to confirm thats the issue. I will try my best to fix it IA
              choose:
  - conditions:
      - condition: state
        state: Ramaḍān
    sequence:
      - choose:
          - conditions:
              - condition: and
                conditions:
            sequence:
                  area_id: reception
                  device_id: delted
                data: {}
                  area_id: reception
                  device_id: delted
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                  device_id: delted
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                  device_id: delted
                data: {}
          - conditions:
            sequence:
                  area_id: reception
                  device_id: delted
                data: {}
                  area_id: reception
                  device_id: delted
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                  device_id: delted
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                  device_id: delted
                data: {}
          - conditions:
              - condition: or
                conditions:
            sequence:
                  area_id: reception
                  device_id: delted
                data: {}
                  area_id: reception
                  device_id: delted
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 2
                  milliseconds: 0
                timeout: '00:05:00'
                  area_id: reception
                  device_id: delted
                data: {}
default:
  - choose:
      - conditions:
          - condition: and
            conditions:
        sequence:
              area_id: reception
              device_id: delted
            data: {}
              area_id: reception
              device_id: delted
          - delay:
              hours: 0
              minutes: 0
              seconds: 2
              milliseconds: 0
            timeout: '00:05:00'
              area_id: reception
              device_id: delted
            data: {}
      - conditions:
          - condition: or
            conditions:
        sequence:
              area_id: reception
              device_id: delted
            data: {}
              area_id: reception
              device_id: delted
          - delay:
              hours: 0
              minutes: 0
              seconds: 2
              milliseconds: 0
            timeout: '00:05:00'
              area_id: reception
              device_id: delted
            data: {}
              and what about media players not playing on my HA, is this a problem too? if it is where I start to debug it?
                firozozman
                    March 19, 2024, 10:27pm
                  58
              Fajr adhan wont play at all. I guess it is triggering at the wrong time and it’s skipping it due to that.
Any fix?
                Aaliankhan
                    March 19, 2024, 11:51pm
                  59
              Do you have the play fajr toggle set to on?
