🔊 Ready to go blueprint for playing adhan / azan on media players with many optional features
hi,
I cant get the automation to work either. I have defined the media players in the script, but I keep on getting the following error msg in the trace:
Error: must contain at least one of entity_id, device_id, area_id, floor_id, label_id.
This is such a great project but as a noob iv been really struggling to get it up and running. I’ve seemed to sorted out the automation using the blueprint but now struggling in Node Red.
Please see my attached Node Red screen with debug messages.
Are the sensor updated according to how Islamic Prayer Times works today ?
When i add Islamic Prayer Times fajr is called:
“sensor.islamic_prayer_times_fajr_prayer”
While in your blueprint it is “sensor.fajr_prayer”
Can you add a debug node and connect it after the node names Prayer Times. Then send a screenshot of what it displays in debug panel. Thanks
Unfortunately no because if I update the blueprint it will break it for the other people who already use it. You can change the entity id to the correct one which you noted
Hello. Can someone please help me? I have tried to set this up but it doesn’t seem to work. I get this error -
"Executed: 23 December 2024 at 12:07:00
Result:
choice: 1"
But i have selected an entity - I have selected a few speakers around my house (Google Mini’s) but still no luck.
In Islamic month sensor (optional), put any random entity. I like to use sun.sun
Thank you but that was already set up so isn’t the issue?
Did you ever manage to fix this error? It seems I am having the same issue.
I see, can you send screenshots of ur setup so I can see thanks
I have sent these to you in a private message. Thank you so much for your support.
I have send you private messages as well,
Salams,
Can you help me set it up? I have it set up but at Prayer times I don’t hear anything on my google mini speakers even though I have it selected.
Salams,
I came here as this is supposed to resolve something I really want to do. I’m new with HA, and I’m not a coder, and this is my first time using this forum and GitHub (all the things that HA got me into!!).
I followed all the instructions here and the automation is still not working. I use to have error messages asking me to add a room, etc… and despite addressing that, it still doesn’t work. I have a media player that is working as I can control it from HA.
Can someone help?
Salaam, can you send me screenshot of how your automation setup
Salams Sir,
I’m not sure if I’m doing this right, but here is what I have from my automation screen:
Hello, can you add a media player to pause? It’s supposed to be optional but I think that’s the problem here
Salams,
Many thanks Sir! It worked just now with the change you recommended! Coincidentally, I was listening to the radio (which I usually don’t do) on the speaker and it paused it and played the Azan. I will make sure nothing is playing for asr and check if it also works.
Again, many thanks!!!
