Hello guys.
I am trying to make a really simple automation to remind me to water my plants.
I already have a light for my plants (they don’t grow because its to dark) that gets switched on at a input_number defined time and turned off after a simple delay.
Thats working really well.
I added a earth moisture sensor that measures the moisture.
And i have a motion sensor next to the plants.
I now want to do the following:
if motion and moisture < target_moisture
blink plant light for as long as motion is detected (1s on 1s off)
loop
Should be easy right?
I did start with the script to flash a light.
and added my conditions.
I did have the problem that the light would start flashing if the wifi connection gets lost. So i added a template to check for “unavailable”. -> fixed
The next problem appeared:
Sometimes the Automation / blink_basilikum / flash_loop script gets stuck.
If this happens the state of the automation and scripts stays at 1 but the light does not blink.
So i added a script_turnoff in each step to reset the scripts (not knowing why it stayed on in the first place)
Next problem: I do a light.toggle to ensure that the state of the light is the same before and after the flash cycle. This should ensure that the plant light thats turned on during the day does not get switched to a different state e.g. off after watering the plant (during the day) or stays on during the night if it gets watered.
But this does not happen, sometimes the state changes. After the watering it turns off (if it was on before watering) or it stays on (if it was off beforehand)
Thinking the script_turnoff kills the script mid cycle i added a input_boolean to ensure that the script_turnoff only gets called when the “two times toggle cycle” is finnished.
It didn’t help.
Now i am stuck with a really complicated setup with two scripts and one automations and a helper but it still does not work reliably.
I am thinking i am overcomplicating stuff. Can somebody give me a hint?
Thanks a lot!
Automation:
- id: 25e4a0dab38e4539a375ea2d3d4cdd6f
alias: Blumenlampe Feuchtigkeiswarnung Basilikum
value_template: '{%if is_state(''sensor.feuchtigkeit_basilikum'', ''unavailable'')
%} false {%elif states(''sensor.feuchtigkeit_basilikum'')|float < states(''input_number.basilikum'')|float
and is_state(''binary_sensor.kuche'', ''on'')%} true {%else%} false {%endif%}'
condition:
- condition: state
entity_id: input_boolean.toggle_basilikum
state: 'off'
- service: script.turn_off
data: {}
entity_id: script.blinkbasilikum
- service: script.turn_on
data: {}
mode: single
max: 2
Script.blinkbasilikum
blinkbasilikum:
alias: blinkbasilikum an
sequence:
- condition: and
conditions:
- condition: state
entity_id: automation.blumenlampe_feuchtigkeiswarnung_basilikum_2
state: 'on'
- condition: template
value_template: '{{ states(''sensor.feuchtigkeit_basilikum'')|float < states(''input_number.basilikum'')|float
- condition: state
entity_id: binary_sensor.kuche
state: 'on'
data: {}
- service: light.toggle
entity_id: light.blumenlampe_basilikum
brightness: 130
transition: 0.5
- delay: '1'
brightness: 130
transition: 0.5
- service: input_boolean.turn_off
data: {}
data: {}
entity_id: script.flash_loop
mode: single
script.Flashloop
flash_loop:
alias: Flash loop
sequence:
- delay: '1'
data: {}
mode: single
