Just starting out setting up my first HA system. Something that I thought would be really easy to do was get my wifi connection set up. But things aren’t working correctly.
I plug in my use wifi adapter (RT8191SU). I see that HA detects the usb event and even lists the device:
> ha hardware info
> - attributes:
> BUSNUM: "001"
> DEVNAME: /dev/bus/usb/001/008
> DEVNUM: "008"
> DEVPATH: /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.4
> DEVTYPE: usb_device
> DRIVER: usb
> ID_BUS: usb
> ID_FOR_SEAT: usb-platform-xhci-hcd_4_auto-usb-0_1_4
> ID_MODEL: RTL8191S_WLAN_Adapter
> ID_MODEL_ENC: RTL8191S\x20WLAN\x20Adapter\x20
> ID_MODEL_ID: "8172"
> ID_PATH: platform-xhci-hcd.4.auto-usb-0:1.4
> ID_PATH_TAG: platform-xhci-hcd_4_auto-usb-0_1_4
> ID_REVISION: "0200"
> ID_SERIAL: Manufacturer_Realtek_RTL8191S_WLAN_Adapter_00e04c000001
> ID_SERIAL_SHORT: 00e04c000001
> ID_USB_INTERFACES: ':ffffff:'
> ID_VENDOR: Manufacturer_Realtek
> ID_VENDOR_ENC: Manufacturer\x20Realtek\x20
> ID_VENDOR_ID: 0bda
> MAJOR: "189"
> MINOR: "7"
> PRODUCT: bda/8172/200
> SUBSYSTEM: usb
> TAGS: ':seat:'
> TYPE: 0/0/0
> USEC_INITIALIZED: "7548762217"
> by_id: null
> dev_path: /dev/bus/usb/001/008
> subsystem: usb
> sysfs: /sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.4
My system info:
System Health
version: core-2021.10.5
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.70
arch: aarch64
timezone: America/New_York
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: failed to load: timeout
host_os: Home Assistant OS 6.5
update_channel: stable
supervisor_version: supervisor-2021.10.0
docker_version: 20.10.7
disk_total: 113.9 GB
disk_used: 2.3 GB
healthy: true
supported: true
board: odroid-n2
supervisor_api: ok
version_api: ok
installed_addons: SSH & Web Terminal (9.0.1)
dashboards: 1
resources: 0
mode: auto-gen
I plug the dongle into my ubuntu laptop and its LED flashes. No lights when I plug into my odroid-n2 box.
Tried following this guide:
- no luck.
I get this:
➜ ~ nmcli radio
WIFI-HW WIFI WWAN-HW WWAN
enabled enabled enabled enabled
➜ ~ nmcli device wifi rescan
Error: No Wi-Fi device found.
USB dongle info from ubuntu laptop:
> inxi -Fxz
Realtek RTL8191SU 802.11n WLAN Adapter type: USB driver: r8712u
> lsusb
Bus 001 Device 009: ID 0bda:8172 Realtek Semiconductor Corp. RTL8191SU 802.11n WLAN Adapter
What gives? Isn’t this a fairly generic wifi adapter? Why would the HA OS not detect this? Is there a way to install the drivers? Is there another wifi adapter that is preferred?
Thanks!
