today you can add only one Tibber token, I use 2 different homes. make it useable to add more than 1 Tibber token.
thanks
thanks
There is an integration called Remote Home Assistant that makes it possible to link two HA installations together.
This might make it possible to use two Tibber accounts, one on each HA installation.
The benefit here is that if the connection between the two homes are down, then each HA installation can work independently still.
GitHub - custom-components/remote_homeassistant: Links multiple home-assistant instances together
