I had this happen twice to me. I reboot the host system via the web GUI and I can no longer access it once the Pi is back online. SSH and Samba still work fine. I tried the restart command with the Hassio CLI and it keeps giving me the error:
core-ssh:~# hassio homeassistant restart
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2f8720, 0x44200fc440)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x390
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x4420144200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x404
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x345e94, 0xd, 0x7fe85b8e69, 0x7, 0x0, 0x0, 0x49a900, 0x0, 0x0, 0x0, ...)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x31c
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x44200829a0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x540
github.com/urfave/cli.HandleAction(0x2dc640, 0x372ff0, 0x44200829a0, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0x118
github.com/urfave/cli.Command.Run(0x345e94, 0xd, 0x0, 0x0, 0x49a280, 0x1, 0x1, 0x350d84, 0x2f, 0x0, ...)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x7b0
github.com/urfave/cli.(*App).Run(0x44200e2000, 0x442000a150, 0x3, 0x3, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x950
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x150
Any ideas?
