I’m new to Home Assistant and have been running it for a few days.
I’ve installed Home Assistant OS on a Raspberry Pi 5 with an NVMe drive using the GeekPi N04 NVME HAT. I changed the boot order to prefer the NVMe drive. However, most times when I try to reboot, it fails to detect the NVMe drive. I have to manually power off and then power on again to get it to boot properly.
This issue only occurs when I select reboot and doesn’t occur when I shut down and power up manually.
Is there something wrong with my hardware or is it software related?
Any help will be appreciated.
Below is the screen that comes up whenever I reboot.
Raspberry Pi 5 - 8GB bootloader: 26826259 2024/09/23 update-ts: 1728233441
I am using the GeekPi Raspberry Pi5 Charger:
27W, 5.1V,5A
I don’t have any other peripherals attached, however the first time this happened I had an empty usb drive connected.
(I thought I’d be able to copy my home assistant backups to a USB drive, but removed it since)
I’m having the same issue with geekpi on HA. I’m using the POE hat version https://wiki.52pi.com/index.php?title=EP-0241
and my POE doesn’t have any under voltage issue.
Most of the time the homeassistant restart works fine but 50% of the time reboot issued from HA cause nvme to be undetected. I have to unplug the Poe cable from pi and back in
Unfortunately I haven’t managed to solve the issue yet. In th meantime I am just shutting down home assistant and pressing the on button after a couple of seconds instead of restarting.
I don’t have a USB keyboard so I first installed Raspberry Pi Os lite enabling ssh.
I then used SSH to downloaded the home assistant image and flashed the image to the SSD.
I also changed the boot order to prefer the SSD.
(That’s a high level explanation, let me know if you need more detail).
I am wondering if this is only happening to Geekpi HATs
Thanks Ausfas. Doesn’t seem like they solved it either.
I am tempted to flash another OS (Raspberry Pi Os or Ubuntu) to the nvme and reboot multiple times to check if the issue persist.
My thinking is if it happens on another OS it’s most likely a hardware issue or else it’s an issue with Home assistant.
Not sure when I’ll get a chance, but I’ll post an update here if I do
I was thinking the same but my feeling is it’s HA, and once you confirm will raise it for the HA core.The issue is once HA issues command to restart the system after upgrades it’s fine but reboot from HA doesn’t work well. So there might be some threads that are not fully closed when that command is executed. Although not entirely HA to blame but for this nvme there some sync is needed.
Although this is all theory and guess…let’s see what we conclude with few resources at hand.
I could buy geekworm PoE hat but issue is that my Zwave board used first few gpio pins which that hat doesn’t expose so can’t use that.
Another thing will try is blenaEtcher as in the past different images on Windows, RPI and else of HA have cased an issue too.
Hey, are here any updates?
I did a fresh installation on my RPI5 before some weeks, but I run in that problem too.
Restart cause a reboot, with high fan speed and no HA boot. After unplug and plug the pi again it boots propery and this high fan speed occurs only 2 secs (instead of permanently).
I now bought the Waveshare POE NVME HAT+ and testing to rule out GeekPi
issue. It seems the same problem first time fine but second time stuck in reboot loop… so it can’t be GeekPi or Raspberry Pi5 unless there is some configuration that is causing an issue with HA.
And yes… when its stuck in loop mode then high speed forever and I need to come to the room to unplug it. Two seconds fan mean its going fine.
Is someone raising an issue in the Git against HA so that HA developers can look into it?
I have had this same issue for quite some time. The issue was not there in the beginning. I bought RPi5 at launch and the official M2. HAT+. Several months rebooting went as it should. I had it automated to reboot every night at 4AM. The only thing that helps is to cut the electricity from the pi, and it will boot up normally when energized back.
Thanks for the heads up. I had a fishy SSD installation over usb before the PCIE on RPi5. That installation required nightly reboots. The reboots came over to the RPi5 with the backup restore to the new installation, but it is now gone thanks to this reboot glitch. Still annoying not to be able to reboot the pi remotely anymore. I must buy a shelly WiFi plug and connect it to cloud to be able to reboot the PI remotely.
I did a TP-Link wifi P300 after my main power and and hooked up my POE SW to that. So if after reboot I don’t get a ping fromRPi then I toggle the PoE cutting power off to Pi and reboot that way… additional hardware…but untill a solution is there…that way at least allows me to remote reboot
anyone was able to fix this? having same issue too, can see someone did not have this issue at all, maybe firmware update fixes this? not sure if possible from HA, was thinking to boot it up from RPI linux and do a FW upgrade
