jo-me
(Jochen Mehlhorn)
November 3, 2017, 7:29pm
1
I noticed that when running HA in a docker container, restarting home assistant (e.g. due to a config change) is only working correctly if I restart the container.
The built-in restart mechanisms (in config panel or calling the homeassistant service) don’t seem to work. It shuts down but is not coming back online.
Is that normal and by design?
Jochen
tboyce1
(Trevor)
November 3, 2017, 8:48pm
2
I don’t think so. I run in docker as well and I can restart from the config panel. It shows a toast saying that it failed, but watching the logs it does actually restart.
tmjpugh
(Tmjpugh)
November 5, 2017, 4:47am
3
I notice in general HA restarts can be inconsistent.
Sometime it comes back and sometime not. This is with docker, HASS.io and manual install.
Personally I prefer restart container as result is consistent and faster.
hijinx
(James)
November 5, 2017, 10:13am
4
If you’re running hassio then the restart ha option in the hassio menu works fine. The restart option in config screen does not work reliability
mkzimms
(Mike)
January 29, 2018, 7:06am
5
I have the same issue, have to restart the container. Has not even once restarted HA correctly from the GUI, even after the initial clean install.
For reference, here is my docker-compose.yaml running on a raspberryPi 3 using the image from https://hub.docker.com/r/homeassistant/raspberrypi3-homeassistant/
Homeassistant Version 0.61.1
Docker version 18.01.0-ce, build 03596f5
version: '2'
services:
db:
image: hypriot/rpi-mysql:5.5
volumes:
- /home/pi/docker/mssql//mysql:/var/lib/mysql
restart: always
expose:
- "3306"
environment:
MYSQL_ROOT_PASSWORD: '<<redacted>>'
MYSQL_DATABASE: '<<redacted>>'
MYSQL_USER: '<<redacted>>'
MYSQL_PASSWORD: '<<redacted>>'
web:
depends_on:
- db
image: homeassistant/raspberrypi3-homeassistant
volumes:
- /home/pi/docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
devices:
- /dev/ttyACM0:/dev/ttyACM0
restart: always
network_mode: host
