Hass.io with a predefined image.
I have access via ssh ( through the ssh addon ).
When I enter ‘reboot’ there, the system goes down, but does not come up again.
@dap35 Do you mean i need to send both commands at same time ?
I just send the “hassio homeassistant stop” command true ssh but wil not be able to send “hassio host reboot” command
Sorry for my lack of knowledge (I’am not a computer expert) Thx for reply
@tboyce1 is correct. Your SSH connection is independant of whether HA is running or not, it runs in a seperate container, so essentially if the host OS on the Pi is running, then you should be fine.
Typically, you just need to restart HomeAssistant (HA), so you only need to issue the ‘hassio homeassistant restart’ command. There are times you may want/need to stop and give you a chance to fix some other things. Then you can use ‘hassio homeassistant stop’. When you are ready to go again, ‘hassio homeassistant start’
