#esphome 2025.10.2
substitutions:
max_temp: "70" # °C
action_single_text: single
action_double_text: double
#max_ble_connections: "5"
entity_id: "1-bad-schalter"
#https://github.com/esphome/issues/issues/2941#issuecomment-1331851692
#https://community.home-assistant.io/t/shelly-plus-1-esphome-bletracker/363549/42
esphome:
friendly_name: "1. Stock Bad Schalter"
platformio_options:
board_build.mcu: esp32c3
board_build.variant: esp32c3
board_build.f_cpu: 160000000L
board_build.f_flash: 80000000L
board_build.flash_mode: dio
board_build.flash_size: 8MB
# board_build.flash_mode: dio
# on_boot:
# priority: 250
# then:
# - delay: 15s
# - lambda: |-
# id(ble_tracker).set_scan_continuous(true);
# id(ble_tracker).start_scan();
esp32:
board: esp32-c3-devkitm-1
flash_size: 8MB
framework:
type: esp-idf
version: recommended
sdkconfig_options:
COMPILER_OPTIMIZATION_SIZE: y
CONFIG_FREERTOS_UNICORE: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_160: y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ: "160"
CONFIG_ESP_TASK_WDT_TIMEOUT_S: "20"
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: n
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
wifi:
ssid: !secret wifi_nonet_ssid
password: !secret wifi_nonet_password
fast_connect: true #required for hidden ssids
reboot_timeout: 10min
#output_power: 8.5
logger:
level: INFO
debug:
update_interval: 5s
text_sensor:
- platform: debug
device:
reset_reason:
# - platform: ble_scanner
# name: "BLE Devices Scanner"
# Enable Home Assistant API
api:
encryption:
key: !secret ha_api_key
ota:
- platform: esphome
password: !secret esphome_ota_password
time:
- platform: homeassistant
#esp32_ble_tracker:
# id: ble_tracker
# #max_connections: $max_ble_connections
# scan_parameters:
# #continuous: true
# interval: 211ms
# window: 120ms
#bluetooth_proxy:
# #connection_slots: 5
# active: true
safe_mode:
button:
- platform: safe_mode
output:
- id: relay_output
platform: gpio
pin: GPIO5
switch:
- platform: output
output: "relay_output"
restore_mode: restore_default_off
- id: internal_temperature
platform: ntc
sensor: temperature_sensor_resistance
icon: mdi:thermometer
entity_category: diagnostic
unit_of_measurement: °C
accuracy_decimals: 1
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 25°C
on_value:
then:
- if:
condition:
- sensor.in_range:
above: ${max_temp}
then:
- switch.turn_off:
- logger.log: "Switch turned off because temperature exceeded ${max_temp}°C"
- id: temperature_sensor_resistance
platform: resistance
sensor: temperature_sensor_voltage
configuration: DOWNSTREAM
resistor: 10kOhm
- id: temperature_sensor_voltage
platform: adc
pin: GPIO3
attenuation: 12db
#wallswitch turned into a binary sensor (push button switch)
#https://github.com/esphome/issues/issues/2825
binary_sensor:
- platform: gpio
pin: 10
filters:
- delayed_on_off: 50ms
internal: true
on_state:
then:
- binary_sensor.template.publish:
state: ON
- delay: 100ms
state: OFF
on_multi_click:
- timing:
- ON for at most 101ms
- OFF for at least 150ms
then:
- logger.log: "Single Click"
- if:
condition:
and:
- wifi.connected:
- api.connected:
# send single click event in case wifi and api are conncected
then:
- switch.toggle: relay
- homeassistant.event:
event: esphome.button_pressed
click: ${action_single_text}
entity_id: ${entity_id}
else:
- timing:
- OFF for at most 149ms
- OFF for at least 1ms
then:
- logger.log: "Double Click"
- if:
condition:
and:
- wifi.connected:
- api.connected:
# send double click event in case wifi and api are conncected
then:
click: ${action_double_text}
- platform: gpio
pin:
number: 1
inverted: yes
mode:
input: true
pullup: true
status_led:
pin:
number: 0
inverted: true
The log is basically empty though
INFO ESPHome 2025.10.2
INFO Reading configuration /config/1-bad-schalter.yaml...
INFO Detected timezone 'Etc/UTC'
INFO Starting log output from 10.1.104.173 using esphome API
INFO Successfully resolved 1-bad-schalter @ 10.1.104.173 in 0.000s
INFO Successfully connected to 1-bad-schalter @ 10.1.104.173 in 0.089s
INFO Successful handshake with 1-bad-schalter @ 10.1.104.173 in 0.104s
[08:13:40.217][I][app:185]: ESPHome version 2025.10.2 compiled on Nov 20 2025, 10:25:34
INFO Processing unexpected disconnect from ESPHome API for 1-bad-schalter @ 10.1.104.173
WARNING Disconnected from API
WARNING Can't connect to ESPHome API for 1-bad-schalter @ 10.1.104.173: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='10.1.104.173', port=6053))]: [Errno 113] Connect call failed ('10.1.104.173', 6053) (SocketAPIError)
INFO Trying to connect to 1-bad-schalter @ 10.1.104.173 in the background
INFO Successfully connected to 1-bad-schalter @ 10.1.104.173 in 2.497s
INFO Successfully connected to 1-bad-schalter @ 10.1.104.173 in 1.134s
INFO Successful handshake with 1-bad-schalter @ 10.1.104.173 in 0.107s
The Reboot request from adc.sensor - message is from Home Assistant, via text_sensor.reset_reason.
To flash the shelly and get the logs I had to move one of my accesspoints slighty. Turns out the shelly didn’t have a stable wifi connection. That is surprising though since all other devices have an excellent connection.
It’d be great if this was the end of the story, but I actually noticed, that when the shelly does have a connection it does not switch the relay anymore when the wall switch is flipped.
It only works when the shelly does not have a wifi connection.
Here are the logs (the shelly has a connection at this point, obviously):
[15:42:51.634][D][sensor:131]: 'Temperature': Sending state 34.13375 °C with 1 decimals of accuracy
[15:43:35.694][D][binary_sensor:039]: 'wallswitch_clicker': New state is ON
[15:43:35.696][D][binary_sensor:039]: 'Wallswitch': New state is OFF
[15:43:35.799][D][binary_sensor:039]: 'wallswitch_clicker': New state is OFF
[15:43:42.757][D][binary_sensor:039]: 'wallswitch_clicker': New state is ON
[15:43:42.757][D][binary_sensor:039]: 'Wallswitch': New state is ON
[15:43:42.860][D][binary_sensor:039]: 'wallswitch_clicker': New state is OFF
[15:43:51.616][D][sensor:131]: 'temperature_sensor_voltage': Sending state 1.40300 V with 2 decimals of accuracy
I flipped the wall switch, waited 5 seconds and switched it again.
The relay should have toggled at least once, but it didn’t. There isn’t a line in the log that says Single Click even though that’s independent of whether there is a home assistant connection. The event esphome.button_pressed isn’t emitted either.
It’s weird, this works flawlessly on other shellys. Any ideas?
I don’t know what you are really trying to approach here.
Why you have click timing on for at most 101ms when you have automation to keep it on for 100ms???
That turns a “flip” switch (physical) into a push button. I then use that to determine if the switch has been flipped only once, or twice in rapid succession.
The 101 instead of 100 is just a precaution. Logging probably adds to the timing, but as you can see it appears that wallswitch_clicker is ON/OFF for a bit longer than 100 seconds.
Sure, I need to fine tune that, but why is the timing ok when the shelly isn’t able to connect to the wifi and is incorrect when it is able to connect to wifi?
Without wifi flipping the switch turns the light on/off. When the shelly is connected to wifi it suddenly doesn’t work anymore.
Can be whatever, esp might react faster when not struggling with wifi.
In any case you need good margin there.
When automation on gpio binary sensor is turning on/off with 100ms delay, this all happens in loop cycle. If something is jamming that cycle, even 200ms may fail.
You are a GENIUS. Thank you so much! I never would have guessed that. 200ms was enough!
It works flawlessly with 101 on 5 other shellys so I never would have guessed that. Thank you!
on_multi_click:
- timing:
- ON for at most 200ms
then:
- if:
condition:
and:
- wifi.connected:
- api.connected:
then:
else:
- timing:
then:
- if:
condition:
and:
- wifi.connected:
- api.connected:
then:
Two more questions, if you don’t mind:
Can I force esphome to use a certain AP? I’d like to try if the other AP doesn’t have a more stable connection.
When the shelly reboots the first flip of the switch is ignored, all other flips work first try. Do you have an idea what the root cause could be and how I can influence it to work first try?
