I’m running an Unraid server and a VM for Home Assistant. Been running with no issues for over a year. I had to restart the container today as I was setting up a new integration, and it was taking forever for the dashboard to come up. I VNC’d into the machine and see it stuck on:
A start job is running for Docker Application Container Engine (12 mins 34s /no limt)
Anyone have an idea what’s going on and how to fix it? Here’s a screenshot of the terminal now:
Well, thanks for your reply. But this is my all new setup and facing this issue, tried 3 times re-performing the installation, still stuck at same location. Any idea?
What version of Hassio you are using?
I have this same problem every time I change to any higher than 2 CPU’s. When it happens I have to force shutdown the VM and then set it back to 2 CPU’s and restart. Then it runs fine. Not a good reply but it is all I have been able to do to resolve the issue,
I am running a in Synology VM Manager and had to reboot my NAS. I ended up shutting down HA from UI and the VM from VM Manager, finally I shutdown the NAS (does not get cleaner than that).
I was stuck on this point on restarting HA, and I found out it can take an excessive amount of time, but give it time … in the end after a long while it did start on my end … so maybe the answer is patience, especially with a fresh setup …
Hi all, revisiting this thread please as naturally my HA is broken, ie not booting up and not accessible from both the GUI or app.
Its returning the same message above others had: “A start job is running for Docker Application Container Engine” when I plug an external monitor into the Raspberry Pi.
I have spent the last fews days googling it but some of the fixes are beyond my understanding. I purchased a new SD card and created a new HA on it and it runs, so guessing its not the Pi. I hadn’t made any changes to my setup in over 6 months and it has been running for 5 years all ok.
Any guidance from those gurus out there on how to repair the :“Docker” or transfer all my setting over to the new SD card would be most appreciated. And yes I was silly enough not to investigate the formal backup process months/years ago!
