Rebooting the Hassio Raspberry Pi server causes Sonoffs to switch on some lights and equipment
When the Hassio Raspberry Pi server is rebooted, the Flood Lights (Sonoff Basic), test light2 that’s being used in place of the Xfinity Modem (Sonoff Dual relay 2) and the test Sonoff Pow v2 all switch on. Enabling the PowerRetain on the sonoffs does not fix the problem. Note that only one of the test lights on the Sonoff Dual is switches on after the Hassio RPi server reboots.
The wiringlight (Sonoff Basic) and test light for the Linksys 8-port Switch (Sonoff Dual relay 1) are not being switched on. The Test Raspberry Pi (Sonoff Basic) remains on all the time and it’s not being switched off. The devices are not connected to the sonoff but the 4CH Pro Sonoff relays for the Linksys 8-port Switch, Pi-Hole Raspberry Pi, Hassio Raspberry Pi and No Device are not being switched on (verified accessing the Sonoff GUI). All the Sonoffs are running Tasmota 5.12.0. I’ve been trying to figure this out for several days and can’t seem to find the issues.
The PowerOnState of the Sonoffs are set to 3 ((default) Turn relay(s) on as last saved).
Current Configuration (PowerState Troubleshooting).yaml (5.0 KB)
