Hi everybody,
Green is my custom sensor that I’d like to display in the same style as red, which is generated natively by Home Assistant.
So RED is simply secondary_info: last-changed
GREEN is
{{ states("sensor.unten_arbeitszimmer_esp32_temperatur") }}°C {% set
temp = now() -
states.sensor.unten_arbeitszimmer_esp32_temperatur.last_changed %} {{
((temp | string).split(".")[0]).split(":")[0:2] | join(":") }}
Please note, these two are based on different sensors; so it is purely coincidental that green is 0:02
and red is 2 Stunden
; green is supposed to be 2 minutes
, red is 2 hours
Thing is, sensor.unten_arbeitszimmer_esp32_temperatur
doesn’t have a last-changed attribute that I can just grab; so I have to help myself by utilizing states.sensor.unten_arbeitszimmer_esp32_temperatur.last_changed
and then do math on it
The format just doesn’t look that nice. If it’s four minutes, I’d like “4 minutes
”, not “0:04
”; if it’s two hours 20 minutes, it’s totally fine to round it down to “2 hours
”, as Home Assistant does natively in most cards with last-changed
In this case, I am using type: custom:paper-buttons-row
for the esp32_temperatur and type: custom:mini-climate
for the card that states “2 Stunden”.
Thanks for your ideas
