The complete error is:
Received invalid command: device_automation/trigger/list
9:30:13 PM – websocket_api (ERROR) - message first occurred at Invalid Date and shows up 11 times
Google hasn’t been kind in finding an answer. I noticed an issue when I tried to create an automation and selected a trigger device. There were no trigger options on the device only ‘Unknown trigger’. I also had issues with automations.yaml and it seemed to become corrupt - wouldn’t open through file editor/nano/samba so I deleted and recreated a blank file.
Would love to not have to start over but it wouldn’t be the end of the world.
Thanks in advance for any assistance and/or telling me where else I should be looking.
That’s not the complete error - please click on the Load Full Homeassistant Log button and copy the actual error message, which will be several lines long (just one copy will do, don’t need all 11 occurrences)
Logger: homeassistant.components.websocket_api.http.connection.2984872272
Source: components/websocket_api/connection.py:84
Integration: websocket_api (documentation, issues)
First occurred: 8:51:06 AM (1 occurrences)
Last logged: 8:51:06 AM
Hi, that’s still not the output that’s needed, sorry. You need to click on the big blue button “Load Full Homeassistant Log” then scroll through the output to the time of one of the occurrences and grab the whole thing.
I ran an update in hopes that would clear something out but no luck. I’m now seeing a couple devices as unavailable. Is this all just a sign that I need to start over and restore from a snapshot?
2020-03-18 08:51:06 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2984872272] Received invalid command: device_automation/trigger/list
In all honesty it’s probably an external service that you’ve set up to speak to homeassistant that is sending either outdated credentials or a wrong format message.
What external services are you using? Ifttt maybe? Or a device tracker?
