I have a sensor that is sending 146 mqtt messages within a couple of seconds. Using mqtt explorer I can see each of these messages being received and I can see these mqtt messages in the mqtt integration in HA.
However when I look to see this within HA or within influxdb/grafana I only see one maybe two values.
I thought that as each mqtt message is seperate it would be written to influxdb as a seperate item but this doesnt appear to be the case.
What am I doing wrong?
The format of the data being received by the sensor is:
Message 289 received on Spectrophotometer at 21:28:
"wave": 752.6,
"abs": 4956.6089
QoS: 0 - Retain: false
Message 288 received on Spectrophotometer at 21:28:
"wave": 750.9,
"abs": 4575.6792
This is my settings in mqtt.yaml
- name: "Spectrophotometer Full Spectrum Wavelength"
state_topic: "Spectrophotometer"
unit_of_measurement: "λ"
force_update: true
value_template: "{{ (value_json.wave) }}"
- name: "Spectrophotometer Full Spectrum Absorbance"
unit_of_measurement: "au"
force_update: true
value_template: "{{ (value_json.abs) }}"
