I have a sensor that sends a REST (http post) json object. The important part is a state change that triggers an automation. However there are other key/value data in the json that I would like to display in badges for informational purposes.
I am considering re-sending the json as MQTT so I can use value_template sensors to display, but this adds extra steps. Is this possible to do directly?
However, doesn’t this integration only refer to a sensor that supports handling REST calls from HA? I’m looking to send an unsolicited POST from the sensor to HA and have HA parse the key/values inside of that POST and use those as sensors.
Also… No I didn’t realize that… infinite loop deleted!
