Receiving Notifications twice on Android
I’ve got a problem that I receive notifications on my android twice. They even show up as two icons in the taskbar. I’m using HA 2022.2.9 and Home Assistant App 2022.2.1-full. This is my automation:
  - service: notify.mobile_app_pixel_6
      message: welcome home
      title: home
It also happens when I just use the “run actions” button, so it has nothing to do with triggering twice I think.
If you have an issue please file it in GitHub making sure to supply the logs requested in the issue template.
Same problem
System Health
version: core-2021.12.10
installation_type: Home Assistant Supervised
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.17-v7l+
arch: armv7l
timezone: Europe/Prague
Android App - 2022.2.1-full
please submit an issue on GitHub and make sure to fill out the provided template including the logs
if you don’t see the template, login to GitHub first then go to link
Same problem here. Not always. Home Wi-Fi and 4G are fine. Wi-Fi at friends house is acting strange. Two notifications, indeed two icons. Also TTS, double spoken.
my comments above still stand, we need a issue logged with logs otherwise we cannot help. Why do people skip over comments that are meant to help them?
I opened - Double notifications on Android · Issue #2554 · home-assistant/android · GitHub
I closed my bug. I am getting double notifications for Smartthings as well. Not all Notifications are doubled but one from ST and HA are. Must be a problem with the mechanism they use to send Android notifications. Other apps do not seem affected.
