Recent OpenZWave Problems
I recently started having issues with some switches in my network and it’s driving me crazy trying to figure them out. I have 28 nodes, mostly older GE/Jasco switches and dimmers, that are a mix of z wave and z wave plus. Within the past week or two, I thought some of the dimmers were unresponsive to z wave commands but it turns out all of my z wave plus dimmers will take about 5 minutes to turn on. After that, I cannot turn them off from the front-end, but if I change some settings in the ozwdaemon i can turn them off that way. My non z wave plus dimmers are not affected by this at all. Further, I also have a Leviton z wave plus switch that will turn on and off from the front-end once, but the front-end will not update the switch to off and therefore I cannot turn it back on again unless I reset the openzwave addon/network. I’m not having any issue with local responses.
Any help would be greatly appreciated. I know that I did a terrible job describing my issue but I really just need help diagnosing my issue. I have no idea where to start, though I feel like the UZB stick itself is a good place to start. Is it possible the stick itself is failing, and if so, how would I test that? please let me know if there’s anything else that would be helpful or if I need to be more specific with anything.
Thank you greatly.
Wait for a WIP patch to hit some next release (hopefully 0.113?), or if you’re using the addon rollback to 0.5.1, or if standalone docker to image tag build-150.
Awesome, thank you!
Any way to rollback to 0.5.1 using HassOS 4.11?
