Recent update to MQTT Switches not working
Hi All,
I have a rasp pi w with a 4 relay board on top of it to run a sprinkler control interface.
In the pi I loaded a MQTT python script that receives the commands from Homeassistant to turn on and off the switches.
I was in a phase of testing it before replacing my disconnected rainbird system and installing it in place when there was an update to the homeassistant. After the update there was a message asking to fix some things on my MTQQ switch configuration.
I had it like this:
switch:
  - platform: mqtt
    state_topic: "home/sprinkler/valve1/get"
    command_topic: "home/sprinkler/valve1/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
  - platform: mqtt
    state_topic: "home/sprinkler/valve2/get"
    command_topic: "home/sprinkler/valve2/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
  - platform: mqtt
    state_topic: "home/sprinkler/valve3/get"
    command_topic: "home/sprinkler/valve3/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
  - platform: mqtt
    state_topic: "home/sprinkler/valve4/get"
    command_topic: "home/sprinkler/valve4/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    retain: false
With this config, I had 4 entities of MQTT switches created and activated from my dashboard. You can see the image below is with the new configuration and there is only one active MQTT switch.
After the update it is like this now.:
mqtt:
  switch:
    unique_id: sprinkler_1_sw
    object_id: sprinkler_1_sw
    state_topic: "sprinkler_valve1/get"
    command_topic: "sprinkler_valve1/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    state_on: "on"
    state_off: "off"
    optimistic: false
    retain: false  # or false if you want to wait for changes
  switch:
    unique_id: sprinkler_2_sw
    object_id: sprinkler_2_sw
    state_topic: "sprinkler_valve2/get"
    command_topic: "sprinkler_valve2/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    state_on: "on"
    state_off: "off"
    optimistic: false
  switch:
    unique_id: sprinkler_3_sw
    object_id: sprinkler_3_sw
    state_topic: "sprinkler_valve3/get"
    command_topic: "sprinkler_valve3/set"
    qos: 2
    payload_on: "on"
    payload_off: "off"
    state_on: "on"
    state_off: "off"
    optimistic: false
  switch:
    unique_id: sprinkler_4_sw
    object_id: sprinkler_4_sw
    state_topic: "sprinkler_valve4/get"
    command_topic: "sprinkler_valve4/set"
    qos: 2
    payload_on: "on" # defined by your device
    payload_off: "off"
    state_on: "on"
    state_off: "off"
    optimistic: false
It’s interesting that always just the last switch loaded in the configuration.yaml works, not all 4 switches.
If I remove the 4th switch from the list, the 3rd will work.
Can anyone guide me to a solution to this issue?
get rid of all the extraneous “switch:” entries. you only need one.
mqtt:
  switch:
    - unique_id: sprinkler_1_sw
      qos: 2
      payload_on: "on"
      payload_off: "off"
      state_on: "on"
      state_off: "off"
      optimistic: false
    - unique_id: sprinkler_2_sw
      qos: 2
      payload_on: "on"
      payload_off: "off"
      state_on: "on"
      state_off: "off"
      optimistic: false
    - unique_id: sprinkler_3_sw
      qos: 2
      payload_on: "on"
      payload_off: "off"
      state_on: "on"
      state_off: "off"
      optimistic: false
    - unique_id: sprinkler_4_sw
      qos: 2
      payload_off: "off"
      state_on: "on"
      state_off: "off"
      optimistic: false
Awesome @finity !! Really appreciate the help. Small miss on my side.
It’s all working now!
