Recognition KlikAanKlikUit in the HA environment
Dear forum members,
Let me introduce myself :slight_smile:
I am from the Netherlands, 66 years old (male) and have recently retired. Thought of a new challenge, namely automating the house using Home Assistant (HA).
Had/have a “KlikAanKlikUit” system with some scenes in it, these work well by the way.
Now I have a RaspberryPi 4B with 8Gb of memory, an RFXCOM-XL and a Sonoff Zigbee 3.0 USB Dongle Plus.
My problem is as follows: When the HA is running and I switch on a lamp via KlikAanKlikUit, it is recognized by the RFXCOM-XL. then I can also include this in an automation. However, I have 3 identical switches from KlikAanKlikUit (ACM-250-LD) in the kitchen, all 3 are recognized, only 1 of them is not included in the circuit. When I operate this in HA, I see that the circuit is being made, but the lamp does not turn on, in the KlikAanKlikUit app you also see that it is on. If I switch it off again in the HA (while it is not on), it switches off again via the HA and the app. However, when this lamp is switched on via the KlikAanKlikUit app, the lamp does turn on and I also see this in the HA environment.
The RFX has already been reset once, removed from the HA environment and disconnected (de-energized). Started HA again without the RFX, turned it off again and reconnected the RFX with the same result as described earlier.
Who oh who can help me with this?
P.S. This story is written in Dutch and translated by Google (I can read the English language!!).
Kind regards, Peter
