Recommend a good WiFi Router
Please note I do not use the cloud at all, the above UI is from my hardware controller.
Yes, TP-LInk does very much seem to be slow on the firmware updates to their router and controller lately. I have talked to them and they have made some changes for me that have been implemented, but other things I have requested have taken them a very long time to implement. They have no set schedule for releasing the updates but if you look at their firmware update download page there have been alot of updates.
I do have to agree with you 1,000 percent on the cloud especially, wrt the fact that as I said in my first long post, not only was there an attempt on stealing my identity which made me permanently hyper-security conscious - and their headquarters being in Shanghai, CHINA meaning the CCCP has direct access to that… That is why I do not use their cloud. If I had known that when I started this journey I might have gone with ubiquiti instread, but their prices are horrible…
For remote access into my network (every single thing I use now is with a unique 30 digit password) to access the router settings I use a vpn running inside a post-quantum tunnel - which allows me to avoid port forwarding - (available free - and descibed in the below picture - but not the vpn part) from Cloudlfare (managed by Home Assistant on my network as decribed here):
I am thinking of putting some kind of hardware firewall between my router and the ONT to ensure no hardware in my local network - that is made outside of my country - can communicate with their manufacturer directly - unles I am making a firmware update, etc.
And how would even a firmware upgrade (check) then work if you use the stock FW?
I can just go to their website and check trhe latest version and download that and import it manually, same thing
But in one of your latest post you praised the cloud check for your devices and even provided screenshots…
I think that is just a lost case (thinking like their is a “national” internet) and you can’t even be sure not leaking data.
Stick with FOSSware like openwrt which makes no calls to anyone’s cloud when not explicitly configured to do so.
Yeah well… It can check for a firmware update - I just don’t have cloud access turned on which means the entire UI cannot be accessed by cloud, only locally. But, I do get your point…
Hi “KruseLuds”,
Re your reply saying
the only flaw I see with your suggestion is, if the point is reached where the person then needs to replace the router, money has already been spent on additional access points and a fancy switch, all of which may not be compatible with the ability to configure all of it under one ui.
That’s why I said
At 2. “Ideally choose an AP brand+model that will fit well with your future Switch and Router if needed.”, and
At 3. “Choose a Switch brand and model that will go with the Router you’d choose if you have to drop your existing router.”
Yes the TP-Link units I have will all work in an independent mode as well and I made the assumption that all other manufacturers would offer the same type of functionality but I may be wrong
