I am new to HA and have a question about presence sensors.
I use already a couple of Aqara motion sensors P1 which works well to detect if someone has entered into a room. As described several times, these sensors are not suitable when someone simply stands still around the room. E.g. watching TV or doing some work at the desk. For this case a mmWave sensor is recommended. I found for example the aqara fp1, aqara fp2 and some from tuya.
Here in Switzerland I can only buy the Aqara FP2. The others I would have to order from AliExpress. Unfortunately, I have not heard much good about the Aqara FP2 so far. It needs a login, ghost people detection etc…Is that correct? Or has this improved in the meantime’
Currently I use HA only with a Conbee 2 stick and the Zigbee integration. So no hubs or anything else.
I want to install one sensor in the living room (20m2) and one in the office (9m2). Main goal is to turn off the light if nobody is in the room.
Yes, he had some interesting points with ESP and the combination of the different sensors.
Do you use one of these sensors? Or can I use one of this sensors (Aqara or Tuya) with my installation (Conbee 2 stick and Zigbee integration)? At the moment my goal is really only to know, is somebody in the room or not.
I don’t have these setup or use them at the moment, my current setup is just detection if I am home or not with validation if the phone is inside or outside the home zone when not leaving the home for a while to trigger my AC and Lights to Turn off it they are on and to switch my Synology Surveillance Center to/from Home mode.
I was planning to try at some point try use the existing BT adapter I have by seeing if there was a way to tell HA what room I am in based on the signal strength since my place is not that large with the main rooms being the lounge room and my bedroom, still researching it as I think of other ideas for my place as I can afford the items.
I use the following in the configuration yamil to force the home zone to be the correct radius for my needs:
zone:
# This will override the default home zone
- name: Home
latitude:
longitude:
radius: 15
icon: mdi:account-multiple
and what I am using for the AC control:
alias: Manage AC
description: >-
Turns on the AC based on Summer and Winter temperature's during the day or
night, else turns it off when not home.
- platform: device
device_id:
domain: device_tracker
entity_id:
type: enters
zone: zone.home
- platform: device
device_id:
entity_id:
type: leaves
id: When Not Home
zone: zone.home
- platform: sun
event: sunrise
offset: 0
- platform: sun
event: sunset
offset: 0
condition: []
- choose:
- conditions:
- condition: trigger
id:
- When Home
- Sunrise
- condition: and
conditions:
- condition: state
entity_id: climate.home_ac
state: "off"
- type: is_temperature
condition: device
device_id:
entity_id:
domain: sensor
above: 30
below: 50
sequence:
- parallel:
- service: climate.turn_on
data: {}
- service: climate.set_temperature
temperature: 25
hvac_mode: cool
- service: climate.set_fan_mode
fan_mode: medium
- conditions:
id:
- When Home
- Sunset
- condition: and
conditions:
- condition: state
state: "off"
condition: device
device_id:
entity_id:
domain: sensor
above: 0
below: 21
sequence:
- parallel:
data: {}
temperature: 25
hvac_mode: heat
fan_mode: medium
- conditions:
id:
- When Not Home
sequence:
- parallel:
- service: climate.turn_off
data: {}
- device_id:
domain: mobile_app
type: notify
title: AC Unit
message: AC Has been turned off.
mode: single
Figured I would share them here whilst on the topic incase you wanted ideas with your presence detection. I’m using entityID’s with the Choose for the actions based on selected entities in the triggers when assigned a name for them first.
Been playing around with them for my other automations with parallel actions with or/and based on what conditions need to be met first.
Your plan to use your BT adapter to find out in which room you are is a good idea. Later I want to do the same. I found already a few videos to this topic: https://www.youtube.com/watch?v=axod3MJmXQk This guy explains in different videos all the steps. Unfortunately, I am using ZHA with conbee 2 and not zigbee2mtt. So I am not sure if I can do this with my current installation.
