I’m planning on mounting a 32" tv on the back porch for the summer. I would like it to display the time, temperature, uv index and other information. I can take care of the lovelace yaml.
Does anyone have a recommendation on what software to use on the raspberry pi 4? It will be plugged into the tv via hdmi. I would like it to be an appliance as much as possible. Ideally the raspberry pi will boot into something and bring up a full screen browser on the lovelace page I create. I would like to be able to remotely reboot the raspberry pi as necessary.
Thank you for the suggestions. I will try the options. Here is a screenshot of the main view which is a current work in progress! It is intended to view viewed from a distance on an exterior mounted 32" tv.
kodi, osmc, libreelec, name it as you like. And if you wish you can display anything else besides the weather, and can be remotely controlled
cheers
tom
