can anyone recommend me a good room detector with long battery life?
Thanks.
Kind regards Werner
Thanks.
Kind regards Werner
Hi there,
since I don’t have a Raumelder yet, I’d rather use Zigbee devices right away.
But it’s a good idea.
Greetings Werner
I think the Nest Protect is a pretty solid (though pricey) smoke detector.
It is not zigbee based, but has quite an edge when it comes to its ‘smartness’.
The Heiman smoke detector (I believe it also is sold under different labels) should serve your needs as well. It is quite smaller than others, which I think is nice.
Hi there,
so it should be Zigbee. The Heiman only has Zigbee 3 in the “hs1sa-e” version.
Unfortunately I can’t find this for sale anywhere.
Nonetheless, thank you.
Greetings Werner
Hallo,
also Zigbee soll es schon sein. Der Heiman hat nur in der Version “hs1sa-e” Zigbee 3.
Diesen finde ich leider nirgendwo zum Kauf.
Dennoch Danke.
Liebe Grüße Werner
