I’m looking to replace a normal single gang switch set (with 3 switches) for a zigbee version for automation. I thought I’d found a perfect replacement for it in the following product, but Aqara have informed me they’re not selling this in the EU (I’m in Ireland) and have no plans to in the near future:
I’m in an old house and the walls are solid concrete so I don’t want to knock out a bigger hole. Does anyone have recommendations for a single gang 3 switch replacement I could get in the EU?
I have used several generic ones from Amazon. The 3-gang I had worked for a couple of years, then became a bit unreliable, in terms of Zigbee connection. It switched the lights on/off ok, but wouldn’t report its state to HA or respond to signals from HA. So I replaced it with this one:
Seems to be working ok so far.
Do you have neutral wires available in the socket? If so, I would recommend getting a switch that will use them. If not, you will have to use a “no neutral required” one, but that can cause problems with low-draw LED lights.
