I recently bought a tuya bulb + PIR sensor to test if this would be a cheap solution for automatic light switches. Turns out it is not, as far as I figured so far, the delay is noticable (3-5s) and this does not bring any convience, even worse, I am annoyed every time now when I walk into the room
This could be due to the tuya integration, which is communicating with china, but I think it is also related to the sensor itself. Turning on the bulb for example in HA or the tuya App works fine in under a second.
I tried local tuya, but it shows an error, but nothing I can fix I assume.
Unexpected exception: [Errno 113] Connect call failed ('192.168.178.62', 6668)
File "/config/custom_components/localtuya/config_flow.py", line 595, in async_step_configure_device
self.dps_strings = await validate_input(self.hass, user_input)
File "/config/custom_components/localtuya/config_flow.py", line 242, in validate_input
interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 1182, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
return await fut
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.178.62', 6668)
However, is there a known motion sensor that works as quick as for example ikeas integration? I read that Zigbee is quicker than W-LAN, so I suppose that is a technical advantage.
Maybe a Aqara P1 ? I plan to remove all bulbs with a Shelly 1P / PM in the future. I do not need different light brightness or colour in my bathroom for exmaple. Saving a few bucks on the bulb will make the transition to shelly cheaper.
