I’m very new to this (haven’t even installed Home Assistant yet) and have a somewhat weak grasp of how my central heating system works. I consider myself a techie, but haven’t done anything with e.g. Zwave, and am not much good at soldering
We have a badly-insulated house, which I’m planning to make more energy-efficient over the next year or so, but the main upshot is that temperature in different parts of the house is very variable and heating bills are annoyingly high, hence the main requirement for TRVs…
I believe it is gravity-fed system (i.e. there is a hot water cylinder) and according to this, is a “Y-Plan” system. The valve is dodgy and needs fixing, though, as the heating gets stuck “on” sometimes, and needs a good old turning-off-and-on-again to turn the heat off
What I’m after is recommendations for TRVs which will integrate well with HomeAssistant (but can also be easily overridden by non-technical people (i.e. the rest of my family) or e.g. be controlled via Amazon Echo or an app. It looks like I also need a boiler controller and a thermostat to talk to that controller as a sort of “turn the boiler off of last resort”.
There is a somewhat interesting caveat to this in that I’m planning to get a Sunamp heat battery put in in the fairly near future in order to cut out gas usage and utilise our solar panels a bit more than they currently are. This will cut out the water cylinder, but effectively the central heating should remain the same, i.e. calling for heat from the new heat source in the same way. I guess that means I don’t want to be spending loads on e.g. the boiler controller if we’re ripping the boiler out in the near-ish future
We are also using Octopus Agile to take advantage of super-cheap or even negatively-priced electricity in the middle of the night, though there hasn’t been a lot of that so far this year. The main reason for this would be the Sunamp, though it will be a while until we can get that installed, but for now we try to manually adjust electricity usage to be outside the 1600-1900 peak and maybe run the energy-intensive stuff when it’s cheaper…
I hope that all makes sense, happy to clarify anything if needed…
