Hi, I’ve got a device tracker that is used to track my OVMS enable car. The device was created by an automation using the device_tracker.see
service, and then I think HA automatically created a known_devices.yaml
configuration file.
I’ve added the device to maps, and things seem to work well enough, but I’d like to customize the appearance of the car on the map, as it shares an initial with another person, and the map card seems to only show initials. A couple of questions:
I read that
known_devices.yaml
is deprecated. How am I supposed to create a trackable device without using theknown_devices.yaml
file? Understanding this seems critical to updating the image/name of the device. (Thedevice_tracker.see
automation responds to alatitude
update sensor from the MQTT OVMS device, in case there’s some other integration I should be using) -
Is there a way to change what icons look like on the map card? My Map dashboard (hopefully the right term) shows people pictures correctly, but the map card on my main dashboard just shows one letter for each person. I just recently added pictures to people, so it might have just not updated yet?
People
are great for putting trackers with pictures. Is it correct to create aPeople
person for my car, or is there some other recommended way to give the car a home on HA?
