Hi, I’d like to set up power measuring throughout my entire apparentment, and for the total usage it seems like the shelly em should do the trick, however for plugs they only have plugs that you put into an existing plug.
I tried fitting a shelly 1PM behind an old plug, which works but there unfortunately just isn’t enough space.
So I’m looking for a built in option to just straight up replace by old plugs instead, does anyone know of a brand that has a good version of power measuring in-wall plugs, with EU (BE) socket that works with home assistant?
