Recommendations for Motion Detection lighting in 2026
Given the recent progress with Matter/Thread, Ikea’s new Matter-based releases, and the new HA Connect ZBT-2, what would you use for motion-based lighting automation if you were starting from scratch in 2026?
I recently listened to an episode of the Vergecast in which a “Smart Home” expert recommended that someone starting from scratch go with Home Assistant and Matter over Thread, which surprised me. That tells me that this stuff is reaching maturity where utility and reliability are beginning to overcome the “fiddliness” of getting/keeping things working.
I am getting ready to do some lighting upgrades in my house. Most of my switches do not currently have a neutral available, so I’m thinking ahead about what direction I’d like to go for automation and whether I should re-run the electrical to bring the neutral back to the switch.
I currently have a few WiFi Kasa switches (for which I had to re-run the electrical), two WiFi Shelly relays, and two Zigbee Sonoff relays. I do not have any presence detection in the home, and simply automate based on Home/Away. Otherwise, things are controlled by voice (Google Assistant), and it’s usually to turn everything in a room or the whole house on or off. My goal is to eliminate voice control and instead fall back on basic switches when the automation isn’t sufficient. I also plan to ditch Google Assistant altogether at some point.
I also have a 3D printer, some decent modeling skills, and some very beginner experience with electronics, ESPHome, and soldering. However, I’m short on time, and there’s something to be said about a ready-made solution that I can install and move on. That being said, the more affordable things are, the faster I can get the ball rolling.
So, if you were in my situation, which direction would you go? I’m hoping for a good discussion on this topic. Thanks for reading!
It is still difficult to say, in my opinion. Matter devices are still new and have not reached the maturity or retail availability that zigbee/zwave already have.
I suppose, that if I was starting from scratch with no prior existing zb/zw dongles or devices, it might make sense to start with thread/matter, even though things might be more limited, over time we could expect things to improve.
All that said, there is @ Do Matter "owners" mind the integrated "kill switch"? 🧱 that may be of concern to someone.
I have a recent thread about the new ikea matter motion sensor, where I provide my experience, which so far works as expected (no better, but no worse than zigbee).
If the budget is there (although you don’t have the time maybe you could pay a electrician), adding neutrals will benefit greatly, also to the lifespan of smart relays/switches as they are able to run cooler when a neutral is connected to them. Depending on the extent of the rewiring, having all the smart relays for the switches in one large electrical panel in the basement may be the most efficient way (but may be overkill).
I am a huge fan of Shelly (I prefer all WiFi) relays behind traditional looking wall switches - they each have their own web UI, integrate seamlessly with HA, and you can turn cloud access to them on/off. You can also turn on the ability for them to act as bluetooth gateways (via Bluetooth Low Energy - BLE). There are two wonderful things about this: 1. Then you can use the BLU line of sensors (such as their tiny inexpensive PIR motion sensors) from Shelly which have batteries that last 5 years, are extremely low/zero latency - and nearly flawless connection to HA because their BLE notification can be picked up by several nearby shelly relays to almost 100% guarantee the update gets to your Home Assistant almost instantly. 2. You can get the BLE IRK (Identity Resolving Key) from your phone and use that as part of the home/not home location sensing in HA. This works greast for iPhones as their WiFi will disconnect when they fall asleep.
I would rather have gotten sensors which use a variety of methods for motion detection, and in my opinion one of the very best is EverythingPresenceOne, but that requires power - however my setup as I was on a shoestring budget was to get PIR* sensors (Shelly BLU Motion are my favorites as mentioned in #2 above).
*PIR sensors only sense movement and when a person is still in a room but sitting still they will then switch to sensing no motion. My HA workaround which works very well for using these to turn lights on and off, is (here is an example for a wall switch controlling lights):
When movement is sensed turn the wall switch controlled lights turn on. However the lights are not controlled by the motion but by a timer the motion sensor starts, so the light stays on for X minutes after the last time motion is sensed (when people leave the room the timer will count down and then when finished the lights will go off). That way people are not left in the dark. Also, if someone turns the lights off manually at the switch when walking out of the room, ignore any motion for 2 minutes so the lights would not go back on when they walk away!
Set up a shelly relay behind the wall switch (in “edge mode”) such that changing the light switch to either on or off will change the lights to whatever state they are not currently in. That streamlines the combination of controlling the lights both remotely and physically so that you do not have to toggle the light switch to get the lights to go on or off and no matter whatr state the switch is in you can still turn the lights on or off remotely.
For the automations to make this magic happen:
  1. Set up these helpers: A. A dedicated timer helper in HA for each situation, B. An input_number helper so you can have it as a slider on a dashboard to change the duration of the timer if you like, C. An input_select helper for the automation to be “Turned On/Off” on a handy dashboard (!), D. an input_datetime to store the last time the related wall light switch was PHYSICALLY turned off.
  2. Set up automations to: A. populate the input_datetime and stoip the timer when the switch is physically turned OFF. B. (Re)start the timer when motion is sensed (only if the automation input_select is set as the automation being enabled and only if the light switch had NOT been manually turned off in the last 2 minutes), B. Turn on the light when the timer is (re)started, C. Turn off the light when the timer finishes or is cancelled. There are other ancillary automations you would need such as D. changing the timer duration when the slider is changed but only if the timer is active, E. starting the timer when the wall switch is turned on, regardless of motion, but only if the input_select has the automation as being enabled, etc.
If you do go the way of the much more expensive not “motion sensor” but “presence sensor” then you wouldn’t need all the timers etc. but there would probably be alot of trial and error to make sure that in fact the lights would not go off if you are still sitting there not moving, etc.
The way I do it you can effectively use a cheaper motion sensor. This has worked perfectly for me. If you are using a smart plug connected to a table lamp however, you would need to leave the smart plug turned on when the automation is changed to disabled so anyone can still reach up to the lamp and turn it on, etc.
Thoughts?
Everything Presence Lite for proper precence sensor where it is acceptable to use USB-power (i.e. a USB power-supply like a USB-charges).
Otherwise I generally recommend just using less expensive PIR motion sensors based on Zigbee from Sonoff/ITead or based on Z-Wavw Long Range froom Zooz where do not need precense sensor.
I am a big believer in testing before buy.
There are zwave relays meant to sit behind wall switches. I used they in fixtures that had no neutral. They work well.
More recently I’ve purchased Orein matter bulbs. I bought a 6 pack and verified
  • vendor app not need for setup
  • No cloud connection needed
  • works without connection to internet
    After using 2 months, I decide to use same bulb in several areas that were low use but could use automation. Outdoor lights/ hallway / in fixture that had no neutral switch
I like the bulb because color change and quick upgrade. Pretty much entire house is all zwave switch however
Prior to Getting matter bulb i tested other products and found them lacking. That said
-smart switch without neutral
-matter bulb that work with no cloud
  • Test one before buy several
  • Stick with what work
  • Consider buy a few extra for future replacement
After lights you can use mmWave or PIR motion. There is new WiFi method for motion detect that work well.
I mostly use my existing PIR motion for security to on/off lights. Exist in every room so simple. Just set on long timer 15m - 30m depend on room use.
Bathroom in use non smart motion and sonic switch. Same in laundry room and garage. They require neutral however
