Hi there,
I wonder if any of you could recommend a zigbee Ceiling Fan compatible with zigbee2mqtt. The list of compatible devices in the zigbee2mqtt webpage is surprising small.
I have found the product bellow, that seems interesting:
However, there is no official support on the zigbee2mqtt homepage. Interesting, the dimmer that is sold in the same webpage above is supported by zigbee2mqtt. Since they seem to be very similar (fan speed seem to be controlled by a dimmer), I wonder if anybody has tested the fan device before that could share his experience…
Otherwise, is there a alternative that works with zigbee2mqtt?
Thanks a lot!
