I’ve been looking for some cheapish plug in / screw in type WiFi bulbs (B22/E27 fitting) that I can get working with Home Assistant.
I’ve an Elec Eng and happy to do a bit of soldering / flashing firmware via FTDI etc. I’ve seen EspEasy which looks good but happy to try something else if the integration between HA and the bulb works.
Any recommendations for type of bulb and firmware used for integration with Home Assistant?
I think I may have found exactly what I’ve been looking for.
Just discovered a brand called “SPARIN” see:
Which looking at the images on Amazon seem to have the same LED circuit / board layout as the AiLight / AiThinker type bulbs but come in various different fittings.
I’m hoping too that I’ll be able to use this jig I purchased off Etsy a while ago so no soldering needed:
Yes so hopefully looks the like same led board, just hope the case is the same so the jig will fit. I’ll post again when it turns up and confirm with pictures but finally this looks great as they do lots of different fittings and (if!) the jig fits would be easy and cheap to make work with HA.
Btw ESPurna seems to be the easiest firmware to setup and also get working with HA for these types of bulbs
The Jig may work as indeed the PCB seems to be the same as the AiThinker one. However, I am not sure about the aluminium casing. It is somewhat different from the AiThinker one, which also can mean that the diameter is different.
Espurna is kind of a one size fits all solution and works great. My AiLight firmware is a bit more simplistic in terms that it only serves as firmware for these type of light bulbs and able to control them (via a browser, MQTT, HomeAssistant, REST API).
Great news! I’ve been following this to see if the bulbs worked as I’ve had them sitting in my HA shopping list for a while after I messed up a different bulb soldering the wires on while waiting for the jig to turn up as I was impatient!
How easy was it to get the case off this bulb? I really struggled to get the case off the previous bulb and ended up snapping a bit off it as I think it was glued on.
