You may need to look into a socket like this if you can install it in range of your network to control it (am not sure if its gonna work with HA as I don’t have a use case for these specific ones to test with):
Country? Voltage? There are people here from all over the world so… I use the Kasa Smart Outdoor Smart Plug by TP-Link (KP400) for Christmas lighting (North America, 120vac 60 hz) Not ideal as it is wifi, but it does work well.
The thing is that there is already a waterproof 4 way splitter installed to the garden and two things are plugged in, the Pool Water Pump and the Pool Heater and I want to control the two individually.
The way it is currently wired: 1 indoor outlet → 10m long common cable dug in the garden and pops up next to the pool ending in a Garden waterproof 4 way Splitter → socket 1 in the 4 way splitter Water Pump, Socket 2 Pool Heater.
Yeah but those are also waterproof connections I again wouldn’t cut those and the Shelly Relays are absolutely not waterproof (or tell me if I’m wrong). It’s a simple thing I need a Smart Switch which I can plug into a normal European F Socket and has IP44 at least that’s it. The whole point is to not cut wires, not to play with the factory waterproof design of the different devices or connectors.
having a look around there is this type that comes up in a search which looks to be tuya based:
Then there is this one that by the specs is listed as z-wave based:
I would go with the z-wave based one myself to keep things not reliant on a internet connection like with tuya based devices. You’d just need a z-wave antenna for the HA host and or a extender if its outside the range of normal operation and that will get you sorted.
Thank you for all of your efforts you’ve put into this, I’ve also spent lot of time today with the search and I have ended up also with the Nedis Smartlife plug which is Tuya compatible. Not the ideal solution as then I will be dependent on the Tuya Cloud service but still a solution to the problem. Maybe I’ll try to flash its firmware to Tasmota and then if will work then I’ll be more than happy but if not then I’ll stick with the tuya integration.
If the flashing works then share how you did it for others that need to use one locally. Else just grab that z-wave base one if its avaliable to save on tuya headaches lol.
I am also looking for an outdoor smart plug, HA-compatible, ideally ZigBee 3.0 since I already have a working Zigbee network, and the plug will be within range.
I found this one: the Nous A6Z. Although it does not appear on the official Zigbee Device Compatibility Repository, I wonder if anyone in the community has tried it out and could advise if it’s a Go or a No-Go.
Any alternative welcome ! And if not possible in ZigBee, WiFi could be a solution, although I avoid as much as possible to have smart devices on the Wifi home network.
I’ve started this topic and I have ended up with this one:
Tested during 1 full season in the garden it has got everyting really rain, storms and daily twice irrigation, and handled it well. So based on my 1 year experience I can recommend this. Handled by the Tuya Local Integration in HA.
