Reconfiguring homeKit and Aqara FP2
Hiya, So I’m having an absolute nightmare with this, and given I’m fairly new to Home Assistant (2 months), I’m cautious about aimlessly fiddling about.
I have a lot of devices in my house, and I started integrating the FP2 mm wave sensors from Aqara recently. I got two and after a pain in the arse trying to set them up using an Android phone, and having google nest Wi-Fi, I eventually got them into the Aqara app by driving away from the house, hot-spotting my phone with the same Wi-Fi name and password, restricting 2.4Ghz, and setting up from the second phone. When returning home they connected to my Wi-Fi OK and worked.
When I got them back online they showed up as new integrations in HomeKit and were easy to add from there using the pairing codes on the back.
Fast forward to a few days ago, I learned that setting up Zones actually creates additional virtual room presence sensors. Great for automations and light tracking. So I ordered three more. However I was premature in my actions. I add them OK (drive down the road and hotspot again) to make sure they worked, once I knew they were paired and they were working in HA, I then went and configured zones on all 5 sensors.
This is where is went wrong. HomeKit started warning “Failed setup, will retry”, and they all got stuck in a state of “initialising”. I tried restarting, clearing cache, configuring, all to no avail. So then I tried taking the zones out the Aqara app, and returning them to the state they were when working, all to no avail. I then restored HA to a backup from the night before when they were working, all to no avail. Nothing would work.
Then I tried resetting the FP2’s back to factory state, and re-adding them to the Aqara app, but they wouldn’t show up in HA. I then tried removing every entity from HomeKit and restart HA, nothing showed up. I tried configuring HomeKit and the message was “No unpaired devices could be found”. I removed HomeKit and restarted HA, same thing. I reset the FP2’s again (down the road, in the car, hot-spotting phone), came back, they work in the Aqara app, but HomeKit still won’t find new entities.
I’ve retried everything in different sequences, HomeKit integration just doesn’t see them, but my router shows them up OK, I’ve given them all static IP’s (even tried new IP’s to fool it), HomeKit just won’t see them at all.
The only thing I can think, is either HA has them cached somewhere and I need to clear that out. Or they’re stored somewhere in HA in the DB or some config file with a mac address or some identifier that means a reset doesn’t make the device appear as a new device, and they need to be cleared out of there. But I don’t know where to look or what to do to make HomeKit think it’s a new installation and allow me to add all my devices back.
Please someone help? I’m not so great with terminal. I have a HA Green. and I have Studio Code Server setup, HACS, and a tonne of integrations and automations for all my stuff which all works OK with the exception of Motion Automations because I can’t get these dam FP2’s back into HA.
:sob: :sob: :sob: :sob: :sob: :sob: :sob: :sob:
So I’ve now spent my weekend doing nothing but trying to fix this, with more than 24 hours awake straight. The crossroads are here! And I’m done in… last question, before i do one of two things…
Will the aqara m2 hub pair with HA and offer up my FP2 Sensors that way?
If yes, then it’s another 50 quid and i try once more.
If no, then the 400 quid of aqara FP2’S go back, the 300 quid of other aqara sensors that works fine on Zha goes back too because f*** you aqara for being all “f*** you android users, if you don’t use homekit you’re not worth our effort”!
This has totally done me in and taken me over the edge!
Unless it cures cancer for your mother → go to sleep!
How did you reset them? Using the button the device? If so it might not be enough; several people in the forum reported that after that it is also necessary to disconnect them from power for few seconds and reconnect. Soft restart by short button press might be not enough. Personally I also run into such issue one time (on 5 sensors).
Resetting was a pain in the hooha! it took quite a few goes on each, but most common variable to produce quickest results was:
  1. Power on, wait 10 seconds (even though it flashes immediately - jumping the gun here the rest would fail)
  2. Press and hold for 10 seconds’ish, till the light goes off briefly
  3. Unplug as fast as you can before the light starts flashing again (missing the target and the light flashed and nothing else would work)
  4. Wait a little while, about 10 or more seconds was ideal.
  5. Power on with USB, and wait about 10 more seconds (bare in mind, jumping the gun early would never work, and everything else would fail and i’d have to start again, or, as per the 120 plus attempts the few hours earlier - i’d try something else in a different way and sequence and it would fail)
  6. short press the button 10 times and then the light will go off briefly, and then start flashing after two seconds
  7. wait another 10 seconds
  8. attempt another pairing with the Aqara app using my two phones hot-spotting in the baking hot car with a seat full of other FP2’s needing the same proverbial kick up the toot.
  9. when the App find’s the Wi-Fi of the device to connect to after it’s done step 2, don’t click it yet! Wait another 5 plus seconds, then click it.
If all goes well, it connects into the aqara app.
Bare in mind, this is all Android, I don’t own any Apple products, at least not since I stopped working for them 19 years ago… i have to be hot-spotting off a second phone using the same SSID and password as my home Wi-Fi, but no where near my home, else it just won’t work.
Once it’s in the Aqara app, that’s it, it now an expensive and useless bookend because HA will never see it again unless you go out and buy apple products to fool it into the HomeKit integration…
The only test scenario I’ve not been able to achieve, and it’s impossible to do so unless I only want to ever monitor presence in my car, is to leave it powered on after binding with the Aqara app, but in all honesty, I can’t see that making a difference. plugged or unplugged, the Aqara app picks it up, HA doesn’t know it exists.
The plus side though, I’ve had 6 awesome steak burgers this weekend, because I have to park outside their shop while a waste my life away trying different scenarios with these FP2’s :joy:
For anyone thinking it’s worth trying to repair their FP2’s at home… don’t!
  1. You can’t choose 2.4Ghz as your preferred network from a mobile
  2. I have Nest Wi-Fi pro, so I can’t disable the other channels
  3. If I switch the Wi-Fi off, my phone goes into melt-down with the millions of devices trying to suddenly connect when I enable the hot-spot
  4. If I kill all power at the mains, then try the two phone hot-spot trick it works, but then go help me with all the fixing I have to do when I put the power back on when camera’s want reconfiguring, and all the devices are upset with me.
I’m having the same problem (no iPhone/Apple user). After creating the zones, HA HomeKit started saying it’s unreachable. I removed it from HomeKit and now it doesn’t detect it anymore. Quite frustrating…
There’s really no fix to this?
Similar situation here. I had the FP2 working perfectly for a few weeks, but wanted to mount it upside down to hide the cable. This broke zone detecion of course and I had to redo the setup in the Aqara app. After that, HA did not recognize it anymore. Since then, I have tried everything I could think and read of, removed the device from HA, reset the FP2 (long button press), factory reset the FP2 (10 sec button press), the debug steps from the docs. I refused to be put off by the OP’s warnings and still tried to follow their desperate attempts with other WiFis and timings - without success as well: HA just won’t show the FP2 as a new Homekit device anymore, as it did in the initial setup.
I’ll report back here in case I get this fixed… until then, any help or hint is appreciated
EDIT: Found this reddit comment by @TheS1ngularity: https://www.reddit.com/r/Aqara/comments/1bg8ate/comment/lemj2bo/
I don’t know how often I unplugged it during the resetting process, but never after setting it up in the Aqara app. This did the trick for me, so I wanted to share it here as well. Thanks!
Hey I was also going crazy with this and randomly connected. Here is what happened.
  • My router crashed and randomly restarted
  • I happen to have home assistant open and here we go, FP2 was there available.
My theory is that when you reset FP2, the Aqara hub connects to it immediately. So it is not available to pair with Homekit anymore. So during the modem reset, FP2 couldn’t connect to anything so it was available. Also during, the yellow light was flashing.
Hope this helps for folks struggling.
I have the same problem and I cannot figure it out. Of the six FP2 sensors I have, three was able to be re-connected after I changed my home router our (and re-did all my Iot devices). Three is stuck in limbo. Works fine in Aqara app, but HA is laughting at me. It sees it, but is does not want to re-connect to it:
“ERROR: Config flow could not be loaded: unknown error”
Really - unknown error. What is the problem, why?
I need help with this. There is NO aqara support.
This should not be that difficult. If other Iot devices can be re-configured, why not Aqara FP2 sensors too?
This is SO frustrating.
I ran into the same issue today. After nearly two hours of Googling and trying various suggestions, the only solution that worked was factory resetting the Aqara FP2 by pressing its button 10 times in a row.
Be aware that this will erase all device settings, including any configured zones. However, if you’ve backed up your zones, you can easily restore them once the device is re-added to the Aqara app.
Hopefully, this helps others who encounter the same problem in the future.
