i used a magichome controller in my old home to light up my desktop.
now after some time a want to use it again.
but my network has changed i it will connect to 192.168.2.110 but i’m now using 192.168.2.0 range.
i have been able te get it in the esphome addon but can’t change the settings or add it in home assistant using integrations.
when i try to use integrations i get a error that there is no api in the config but i have a back-up file from a older esphome and there is a api in the congif.
when i try to push a now config i get:
In file included from src/esphome/components/api/api_connection.h:7:0,
from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/api/api_server.h:19:25: fatal error: ESPAsyncTCP.h: No such file or directory
* Looking for ESPAsyncTCP.h dependency? Check our library registry!
* CLI > platformio lib search "header:ESPAsyncTCP.h"
* Web > https://platformio.org/lib/search?query=header:ESPAsyncTCP.h
#include <ESPAsyncTCP.h>
compilation terminated.
*** [/data/desktop/.pioenvs/desktop/src/esphome/components/api/api_connection.cpp.o] Error 1
In file included from src/esphome/components/api/api_server.cpp:1:0:
LOGS: INFO Reading configuration /config/esphome/keukenblad.yaml... WARNING The esphomeyaml section has been renamed to esphome in 1.11.0. Please replace 'esphomeyaml:' in your configuration with 'esphome:'. INFO Starting log output from 192.168.2.110 using esphome API INFO Connecting to 192.168.2.110:6053 (192.168.2.110) WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.2.110: [Errno 113] No route to host). Re-Trying in 1 seconds INFO Connecting to 192.168.2.110:6053 (192.168.2.110)
Yaml:
esphomeyaml:
platform: ESP8266
board: esp8285
wifi:
ssid: /
password: /
manual_ip:
static_ip: 192.168.2.110
gateway: 192.168.2.254
subnet: 255.255.255.0
light:
- platform: rgbw
red: red
green: green
blue: blue
white: white
effects:
# Use default parameters:
- random:
# Customize parameters
- random:
name: "My Slow Random Effect"
transition_length: 30s
update_interval: 30s
- random:
name: "My Fast Random Effect"
transition_length: 4s
update_interval: 5s
- strobe:
name: Strobe Effect With Custom Values
colors:
- state: True
brightness: 100%
red: 100%
green: 90%
blue: 0%
duration: 500ms
- state: False
duration: 250ms
- state: True
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 500ms
#remote_receiver:
# pin: GPIO4
# dump: all
binary_sensor:
- platform: status
name: 'Desktop Led status'
output:
- platform: esp8266_pwm
pin: GPIO12
frequency: 1000 Hz
pin: GPIO5
frequency: 1000 Hz
pin: GPIO15
frequency: 1000 Hz
pin: GPIO13
frequency: 1000 Hz
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
password: '/'
ota:
password: '/'
