I’ve been rebuilding my home network to use OPNsense firewall, Cisco switch, and using my old router as AP now. In doing so my Home Assistant server has changed IP address, and is also on a different VLAN than my Wifi AP (and by extension, all my esphome devices). None of my esphome devices are now connected to Home Assistant, although I can see they did get IP addresses from DHCP on OPNsense.
I had intended to manage the changeover assuming I might have to reflash OTA to the espHome devices, but looking at the yaml now, I can only see settings for wifi which has not changed.
So my question is, what do esphome devices use to communicate to the server? Hostname? IP address? Which part have I likely broken, and need to look at to fix?
For info, my firewall currently has a temporary rule to allow all communications, so can rule out firewall. I have moderately well learned and can investigate my DNS, NATs, DHCP, etc. I’m just looking for clues where to start, as examining the esphome device’s yaml gives no clues as to how the devices are trying to find the server. I am even able to get onto the web GUI of the Athom smart plugs, which means I’ll be able to OTA reflash those at least, but can’t find any clues there.
Thanks for this, you saying .local reminding me I’ve changed domain name.
In the yaml, wifi section, I’ve added:
domain: .mydomain
use_address: 192.168.x.x
I’ve been able to successfully flash OTA, and ESPHome now shows the device as online! One step closer.
The entities however (inputs and outputs for buttons) still show unavailable, I’m investigating that.
Thanks also for this, this was the second step.
Deleted the ESP home device, added new device by known IP address, and voila - it comes back live and happy, and already links to the buttons on my dashboard.
Final thing out of place; I can see this device in Settings->Devices and Services-ESPHome, but do not see it in the ESPHome button from the main page sidebar. As far as I’m aware, that’s the only place I can flash new YAML OTA, so now although my device is working I don’t see any way to edit it’s configuration if I need to. Is there a way to get it back into the ESPhome page on the sidebar, or alternatively is there a way to edit and flash YAML from the Device info page?
Assuming you are running HAOS, put the yaml file that you used to flash it in the first place into /config/esphome. That will get you an entry in the addon (ie when you click the sidebar)
If there is a panel there for the yaml file, but it is saying offline, it may be due to your networking. mDNS does not broadcast over subnet boundaries.
