Hi! I am an absent-minded Home Assistant user, and was thinking on a feature. The idea is:
- Some mechanism to add a message
- Some mechanism to attach a zone (plus some flags) to that message
- When a device enters / exits / goes toward the zone, notify that.
The idea is, “Remember to hang up clothes” attached to “arrive home”. Or “Buy groceries” when “going away from work”. I have a Telegram notify for that matter (in fact, each householder has one Telegram notify component).
What do you think would be best for that feature? A custom component? An AppDaemon? Some synergy between components which I am not seeing? It should be dynamic, and using the proximity component seems a good call (I am already using it and have owntracks installed).
What are your thoughts? Does that make sense? Which is the best approach?
