Just updated to 0.42.2 from 0.41 and now the recorder component fails every time I restart with the following error:
Apr 09 14:12:12 raspberrypi2 hass[6359]: 17-04-09 14:12:12 INFO (MainThread) [homeassistant.setup] Setting up logger [100/445]
Apr 09 14:12:14 raspberrypi2 hass[6359]: 17-04-09 14:12:14 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (psycopg2.Programm
ingError) relation "ix_recorder_runs_start_end" already exists
Apr 09 14:12:14 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")']
Apr 09 14:12:14 raspberrypi2 hass[6359]: 17-04-09 14:12:14 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (psycopg2.Progr
ammingError) relation "ix_recorder_runs_start_end" already exists
Apr 09 14:12:14 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")'] (retrying in 3 seconds)
Apr 09 14:12:17 raspberrypi2 hass[6359]: 17-04-09 14:12:17 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (psycopg2.Programm
Apr 09 14:12:17 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")']
Apr 09 14:12:17 raspberrypi2 hass[6359]: 17-04-09 14:12:17 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (psycopg2.Prog$
Apr 09 14:12:17 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")'] (retrying in 3 seconds)
Apr 09 14:12:20 raspberrypi2 hass[6359]: 17-04-09 14:12:20 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (psycopg2.Programm
Apr 09 14:12:20 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")']
Apr 09 14:12:20 raspberrypi2 hass[6359]: 17-04-09 14:12:20 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (psycopg2.Progr
Apr 09 14:12:20 raspberrypi2 hass[6359]: [SQL: 'CREATE INDEX ix_recorder_runs_start_end ON recorder_runs (start, "end")'] (retrying in 3 seconds)
Apr 09 14:12:22 raspberrypi2 hass[6359]: 17-04-09 14:12:22 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
Apr 09 14:12:23 raspberrypi2 hass[6359]: 17-04-09 14:12:23 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (psycopg2.Programm
Setup failed for recorder: Component failed to initialize.
Apr 09 14:12:45 raspberrypi2 hass[6359]: 17-04-09 14:12:45 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of history. Setup failed for
dependencies: recorder
Apr 09 14:12:45 raspberrypi2 hass[6359]: 17-04-09 14:12:45 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not setup all dependencies
Apr 09 14:12:45 raspberrypi2 hass[6359]: 17-04-09 14:12:45 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of logbook. Setup failed for
Apr 09 14:12:45 raspberrypi2 hass[6359]: 17-04-09 14:12:45 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not setup all dependencies
I’m using postgres for the backend (setup using these instructions).
Not really sure where to go from here. Is anyone else experiencing this issue?
