Recorder configuration error
My db file is growing so I added recorder configuration to keep only 2 weeks of data.
Just added the following to the config
recorder:
  purge_keep_days: 14
Restarted home assistant and got this error:
ERROR (MainThread) [homeassistant.config] Invalid config for [recorder]: some but not all values in the same group of inclusion 'purge' @ data['recorder'][<purge>]. Got None. (See /var/opt/homeassistant/configuration.yaml, line 49). Please check the docs at https://home-assistant.io/components/recorder/
I double-checked config and searched for similar errors but cannot figure out what im doing wrong. The recorder component page does not specify any non-optional parameters and i think something is missing… but what ?!
I think purge_keep_days: needs to be indented
recorder:
   purge_keep_days: 14
thats ok in my config…
by the way, how to indent here on the forum ? tried preformated text but did not work…
There is a link describing how to format in the big blue box at the beginning of every topic.
My configuration also has a purge_interval, but I don’t know if that is required
recorder:
  purge_interval: 1
  purge_keep_days: 3
  exclude:
    domains:
      - weblink
      - updater
Added purge_interval and i have no more error.
Thanks.
The component doc contains an error: https://home-assistant.io/components/recorder/#purge_interval is marked as optional but it is not…
Now waiting to see if purge is effectively performed.
Thanks!
It’s still required in v114, but not even listed doc linked to above.
