Rebooted my Ubuntu 18.04/docker/Hass.io(0.98.3) system to update the OS. And now I’m getting Recorder errors as:
2019-09-04 20:06:23 INFO (MainThread) [homeassistant.setup] Setting up http
2019-09-04 20:06:23 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-09-04 20:06:23 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-09-04 20:06:23 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-09-04 20:06:23 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-09-04 20:06:25 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
(Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
2019-09-04 20:06:28 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:31 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:33 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2019-09-04 20:06:34 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:37 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:40 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:43 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:46 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:49 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: (MySQLdb._exceptions.OperationalError) (1130, "Host '15ef4d2f-esphome.local.hass.io' is not allowed to connect to this MariaDB server")
2019-09-04 20:06:52 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 28.7 seconds.
2019-09-04 20:06:52 ERROR (MainThread) [homeassistant.setup] Setup failed for recorder: Integration failed to initialize.
2019-09-04 20:06:53 INFO (MainThread) [homeassistant.setup] Setting up zwave
2019-09-04 20:06:53 INFO (MainThread) [homeassistant.setup] Setup of domain zwave took 0.0 seconds.
2019-09-04 20:06:57 INFO (MainThread) [homeassistant.components.zwave] Z-Wave USB path is /dev/serial/by-id/usb-0658_0200-if00
___SNIP___
2019-09-04 20:30:54 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of history. Setup failed for dependencies: recorder
2019-09-04 20:30:54 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Could not set up all dependencies.
My MariaDB config:
"databases": [
"homeassistant"
"logins": [
"username": "hass",
"host": "homeassistant",
"password": "secretpassword"
"rights": [
"username": "hass",
"database": "homeassistant",
"grant": "ALL PRIVILEGES ON"
And the bits in HA config:
recorder:
db_url: mysql://hass:secretpassword@core-mariadb/homeassistant?charset=utf8
purge_keep_days: 90
exclude:
entities:
- sensor.date
- sensor.time
No errors in MariaDB logs.
Why/what is (Host ‘15ef4d2f-esphome.local.hass.io’) trying to connect and borking the recorder?
Help please.
