Ascari
(Arancio)
1
I try to limit the history recording of my HA.
But I thing I do a error in my db_url, I use the Sqlite and Hassio.
Somebody know the correct path ?
Recoder DB
recorder:
purge_keep_days: 5
db_url: sqlite:////config/home-assistant_v2.db
include:
domains:
- sensor
Thx
Tediore
2
You don’t need to configure the DB path if you’re using the default DB.
If you’re using the default SQLite database that HA creates, you do not need to specify the db_url:
Edit: @Tediore ninja’d me
Ascari
(Arancio)
5
Ok thx, it’s because I see in the doc (wiki) required for this field.
Tediore
6
It says db_url
is optional.
