hello,
I’m new to this forum.
and newbi to homeassistant too.
my configuration is:
- a base board with a raspberry pi CM5 board, with 32GB of eMMC flash and 8GB of sdram
- raspbian os installed on the embedded flash
- homeassistant 2025.3.4 installed in a docker
- Mosqitto installed
the database is SQLite, and I would like to relocate the db file on another media, I saw that this is possible by adding a ‘recorder:’ section in the configuration.yaml.
However, I tried a lot of combinations for db_url, but nothing seems to be working.
I also tried to put the recorder section in a secrets.yaml file.
to proceed with some tests, I have made a copy of the home-assistant_V2.db file to /home/jlsun folder.
at this time the database has a size of 2MB (a few events recorded, I started the MQTT connection to a device yesterday)
this is what should normally work (I saw many examples all arround, it seems that 4 slashes are needed)
even when using the original location
(/home/jlsun/Homeassist/home-assistant_v2.db)
it does not work (HA gives a message at restart and SQLite temporary files are not created)
Can someone help me, I didn’t find anything in many places on the web, looked into this forum too, the only approaching thread here is from 2016 and I saw the same recommended syntax, it should work but mine does not.
the definitive db_url will be on a usb sdcard (‘disk’ on the screenshot)
I have a french version of HA.
could it be a text encoding problem for HA to manage the db_url string ?
or something to do with HA docker ?
thanks in advance
