Recorder does not purge
I try to understand why my postgresql database is growing and finally I’ve found that hass does not purge anything.
My oldest event actually is date on 21/8 in the events table but when I run a purge here’s what I see in the debug log:
2018-09-24 17:22:12 DEBUG (Recorder) [homeassistant.components.recorder.purge] Purging events before 2018-09-22 15:22:12.343414+00:00
2018-09-24 17:22:12 DEBUG (Recorder) [homeassistant.components.recorder.purge] Deleted 0 states
2018-09-24 17:22:12 DEBUG (Recorder) [homeassistant.components.recorder.purge] Deleted 0 events
2018-09-24 17:22:12 DEBUG (Recorder) [homeassistant.components.recorder.purge] DB engine driver: psycopg2
and in the database:
hass=# select event_id,event_type,created from events order by created limit 1;
event_id | event_type | created
2115 | state_changed | 2018-08-21 07:06:54.409343+02
(1 row)
Any idea what’s wrong in my config ?
To be able to restore state on startup, the last known state for each entity is never deleted. This is true even if you remove an entity.
So I guess that the number of old records is quite small and will match entities that you no longer use.
It’s so obvious when you say it…
I ran the query one more time today with keep_days = 1 and…
2018-09-25 13:32:42 DEBUG (Recorder) [homeassistant.components.recorder.purge] Deleted 12193 states
2018-09-25 13:32:43 DEBUG (Recorder) [homeassistant.components.recorder.purge] Deleted 16086 events
Now I have to find what I need to exclude to avoid large database.
Query sorted by most entries:
SELECT
 entity_id,
 COUNT(entity_id)
FROM
 states
GROUP BY
 entity_id
ORDER BY COUNT(entity_id) DESC
LIMIT 20;
Thanks, I’ve run something similar and found that my cpu and mermory monitoring no the host was the most expensive consumer here.
And I don’t need local history because I already have influxdb.
