I am still seeing mqtt events showing up in event log. I am sending a heartbeat to sensors so this adds a ton of events to the events table. Below is my config:
Because you can’t use globbing to indicate multiple entries outside of a complete domain, I’ve used this gem extensively in the template dev tool to generate a list of entities:
{% for i in states.switch if 'keypad' in i.entity_id %}
- {{ i.entity_id }}
{% endfor %}
{% for i in states.switch if i.entity_id.startswith('foo') %}
- {{ i.entity_id }}
{% endfor %}
Somehow the quotes in the second one got replaced by the wrong kind. I’ll update the original one, but you can swap them manually. These are just examples of what you can do.
