Hi!
It’s possible to include ONLY some sensors in recorder configurations?
I have a lot of entities, including sensors, that I don’t want to record…some of theses sends a lot of data per minute and I don’t want to add everyone to exclude list in my recorder config…so my question is, is there any way to exclude everything and include just some specific itens to recorder?
I have tried this configuration, but it doesn’t work (as expected, acording to documentation):
purge_keep_days: 7
commit_interval: 60
include:
entities:
- sensor.temperatura_externa
- sensor.umidade
- sensor.velocidade_do_vento_media
- sensor.velocidade_do_vento_maxima
- sensor.temperatura_painel_solar
- input_select.maquina_de_lavar
- sensor.caixa_dagua_percentual
- sensor.temperature_caixa
- sensor.energy_real_consumed_fronius_meter_0_http_192_168_22_46
- sensor.energy_real_produced_fronius_meter_0_http_192_168_22_46
- sensor.energy_total_fronius_inverter_1_http_192_168_22_46
- sensor.quarto_jonis_e_pri_temperatura_humidity
- sensor.quarto_jonis_e_pri_temperatura_temperature
- sensor.area_de_limpeza_maquina_de_lavar_energy
- sensor.sala_de_jantar_adega_energy
entity_globs:
- sensor.sala_temperatura_*
- sensor.sala_de_jantar_temperatura_*
- sensor.escritorio_temperatura_*
- sensor.garagem_temperatura_viveiro_*
- sensor.plantas_*
- sensor.temperatura_boiler*
- sensor.area_de_limpeza_maquina_de_lavar_*
exclude:
domains:
- automation
- binary_sensor
- calendar
- camera
- climate
- device_tracker
- group
- input_text
- input_number
- light
- lock
- media_player
- remote
- script
- sensor
- sun
- switch
- zone
- weather
The problem
is that when I exclude a domain, they are not including in ‘include’ key, as ‘exclude’ has preference in logic.
Not that this configuration doesn’t produce any error, syntax is right…just the devices isn’t recorded.
